How long to put in new motor?
Old Sep 26, 2005 | 01:50 PM
nismoluvr's Avatar
I am looking to swap in a motor with less miles, but just curious how long it takes.... For those that did the swap, anything that really sucked (particular bolts that don't come out nicely, headaches, etc...).....
I have a 95 Maxima and plan to find an exact motor to swap in just FYI.
Thanks for the help guys!
Jason
Old Sep 26, 2005 | 03:32 PM
scrhale's Avatar
Dude ... just 3.5 swap. It is not that much more. You can get a full block with some miles for 700-900 if you look.
Old Sep 26, 2005 | 05:46 PM
86maxima96's Avatar
I Broke OT
^^^but then you might as well go 6 speed... 3.5 really isn't that close to 3.0 interms or work and $$$, is it?
Old Sep 26, 2005 | 06:12 PM
NmexMAX's Avatar
dot dot dot ...
6 spd is
Keep the 5MT .... This can be debated though, but if you're just planning on doing an engine swap, i'd personally go w/ a 3.5 as well, but to stay as cheap as possible, leave whatever tranny is already in there ...
BTW< why are you changing your engine anyway, what's wrong with the one in there now?
Old Sep 26, 2005 | 06:18 PM
86maxima96's Avatar
I Broke OT
ok, i know there are FAQ's and all for this type of thing, but if my engine crapped out in, oh say two years, is it worth it to put in a 3.5? or just sell it? I am pretty comfortable with any bolt on, but what skill is needed for a swap?
sorry, i'll just check FAQ's on this one.
Old Sep 26, 2005 | 06:22 PM
NmexMAX's Avatar
dot dot dot ...
It depends on what you think is "worth it" ... 30-40 peak whp is in my book, and more importantly 20-25 more ft/lbs thruthe entire powerband would be for me..
If you have a 2nd car to get to work and back ...
Old Sep 26, 2005 | 06:42 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
plus the 3.5 sounds MUCH better...
+1 for 3.5 swap
Old Sep 26, 2005 | 06:44 PM
NmexMAX's Avatar
dot dot dot ...
+1 for 3.5 swap
It's pretty much a no brainer if you're going to go ahead and do a swap in the 1st palce
Old Sep 26, 2005 | 06:48 PM
thats why I said "+1 for 3.5 swap".....?
Old Sep 26, 2005 | 07:02 PM
NmexMAX's Avatar
dot dot dot ...
Old Sep 26, 2005 | 07:54 PM
Jime's Avatar
Did a swap last sat, took 5 hours but that only includes actual swap not the time to unhook wiring, drain fluids etc etc. I am still not quite ready to start it up, still have one axle and fluids to put in first.
Old Sep 26, 2005 | 07:58 PM
xloki77x's Avatar
if you do the 3.5 swap, will it bolt up to the vq30 tranny?
Old Sep 26, 2005 | 08:11 PM
NmexMAX's Avatar
dot dot dot ...
Yes. ..
Old Sep 26, 2005 | 09:45 PM
suicidalspd99
How about the 3.5 mated to a auto trans?
Old Sep 26, 2005 | 09:46 PM
Jeff92se's Avatar
I'm needing a caw
How about the Q45 motor and awd?
Old Sep 26, 2005 | 09:49 PM
Nealoc187's Avatar
SLOW
Took me 17 hours from the time I pulled the car in the garage to starting it up with the new motor. That was with alot of breaks and screwing around trying to take the old motor apart, lots of trips to the parts store, no engine stand, etc. This was with a turbo car that was formerly an auto so there was some additional time for things that are not normally an issue such as re tapping for oil feed and return, etc. I could probably do it again in 10 hours from jack pump to engine start. It was also between 105-110 in the garage on the 2 days I was doing it so there was alot of water drinking and going inside into the air conditioning wasting some additional time.
soloist3
Sep 2, 2015 12:59 PM
raffivegas
Aug 23, 2015 09:54 PM
doobadoo
Aug 15, 2015 06:43 PM
sc10692
Aug 9, 2015 09:37 AM
