wheel stud and lug nut problems
Old Sep 26, 2005 | 05:02 PM
96blackmaxSE's Avatar
boost me.....
it seems everytime i take my wheels off, wheel studs get cross-threaded and sometimes the ends of the wheel studs break off inside the lugs when im taking them off...so now i am missing/have cross-theaded at least 1 wheel stub on each corner of my car...(its angering me b/c ive arleady replaced about 7)...
what i want to do now is to switch all my wheel studs out to ones that do not have as fine thread patterns, longer(extrud more from hub) and stronger ones
then hopefully they will not break off or get crossthreaded anymore
MY QUESTIONS ARE:
1. has anyone had bad luck with studs/lugs like me?
2. has anyone ever switched out to not as fine/longer/stronger studs?
3. if so, what brand and where did u buy them??
Old Sep 26, 2005 | 05:07 PM
ThisMaxIsTight's Avatar
i have 2 broken studs .. one on one tire and one on another ... im just gonna be more careful when I put my lugs back on ... maybe ill use antisieze from now on
Old Sep 26, 2005 | 05:16 PM
MaximaSE96's Avatar
Maxima Owner
yea i had an issue with them....but mine was the wrong lug nuts......then everytime i put new studs on ta diff one would strip....but i got it all sorted out now
Old Sep 26, 2005 | 05:22 PM
njmodi's Avatar
Do I get a tax break?
MY QUESTIONS ARE:
You must be overtightening the wheels... the lug nuts are supposed to be torqued to 70-80 ft-lbs (or around that range)... I would definitely be wary of using anti-seize on the lug nuts... you don't want those coming undone while driving...
Old Sep 26, 2005 | 05:25 PM
boost me.....
what did you do to get them "all sorted out"...
Old Sep 26, 2005 | 05:35 PM
86maxima96's Avatar
I Broke OT
how so??
Old Sep 26, 2005 | 06:05 PM
njmaxseltd's Avatar
Use Anti-Seize - The **** works!
And be a bit more carefull when you thread your lug nuts on.
Use a torque wrench, only 80 ft/lbs are required to secure your lug nuts.
Old Sep 26, 2005 | 06:09 PM
hey Tom, how much to do 2 studs on 2 different axles ?...to be more clear, my front tire is missing a stud and my back tire is missing a stud
Old Sep 26, 2005 | 06:12 PM
boost me.....
im not gona put that on my lugs...i dont trust it taht it will keep my lugs on when i most need them...(while im driving)*edit* the anti-seize stiff
Old Sep 26, 2005 | 06:19 PM
siballiance's Avatar
yea i had to change all the studs and nuts
had a sh!tty day .. he gave me from infinity studs, they smaller
so i had to change..
but u take off brake cliper and rotor, with a hammer smash bolts u dont need, and just buy them in autozone like 2$ each
Old Sep 26, 2005 | 07:52 PM
hitman4's Avatar
i got the same problem on my 97... all the time
I just keep on buying new studs and lug nuts
Old Sep 26, 2005 | 07:54 PM
hitman4's Avatar
OH...and just an FYI...I was missing 3 lugs on front dirivers at one time and drove to NC and back.....got back in one piece.
Old Sep 26, 2005 | 09:33 PM
BEJAY1's Avatar
Conecarver
Actually I find the OEM lugstuds on my '97 are excellent compared with many other mfg (Honda) out there which break frequently. I've torqued my rears maybe 140+ times over 7 years and not one has broke yet. For anybody it helps...
1) I break em loose with an old beam torque bar
2) Spin em off with a drill or impact
3) Check there's a hubcentric ring present
4) Hand thread em to start em back on (never used anti-seize)
5) Spin em back on using a red torque-stick
6) Final tighten with a decent torque wrench
My H&R studs are just as strong and I'm sure Nismo and ARP are similar. Maybe the key is getting them started correctly and not using an airgun from the start? Or the frequent removal/install keeps em happy?
lowpost99
Oct 26, 2025 06:53 PM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
