engine transplant
Old Sep 26, 2005 | 08:48 PM
konak85's Avatar
engine transplant
I got a question guys. I have '96 auto. i think the all maxima motors are completely interchangeable, but i'm not sure. Will a '97 motor swap in without any problems? Does it matter if the donor engine is auto or manual?
Old Sep 26, 2005 | 08:58 PM
Nissan 6's Avatar
3.5 it, but yes the 97 motor would fit no problems because its still a vq30de
Old Sep 26, 2005 | 09:37 PM
NmexMAX's Avatar
dot dot dot ...
Drop a VE in there ...
Old Sep 26, 2005 | 09:43 PM
tavarish's Avatar
fwd gone rwd cr00
VQ ownz j00.
Yes, all engines from 95-99 are interchangeable, the 95's have different emissions equipment than 96-98, and the 99's are calispec, and have so much extra crap it's not even funny.
Old Sep 27, 2005 | 04:23 PM
konak85's Avatar
i knew the '95 and '99 might not have worked as easily. I think '95 is ODB I and '99 has a bunch of crappy emmissions stuff an f'ed up coils. i guess '96-'98's good thanx tav
Old Sep 27, 2005 | 05:37 PM
MDeezy's Avatar
whats wrong with your current motor? Entertaining the thought of switching to a Manual?
Old Sep 28, 2005 | 04:02 PM
overcastfab's Avatar
my '95 gle has 140k on it. so i've been teasing myself about getting a new engine and switching to 5spd
Old Sep 28, 2005 | 04:12 PM
MDeezy's Avatar
140K on the motor is mid life for it and can go atleast another 140K.
Old Sep 28, 2005 | 04:26 PM
NmexMAX's Avatar
dot dot dot ...
I have 231k, and still sees 7+k daily (f'uck how many times have I said that already)
Seriously, don't waste your money or your time.
But if you're doing it to upgrade to a 3.5L,,,, by all means
Old Sep 28, 2005 | 05:10 PM
MDeezy's Avatar
Damn you rev that old *** engine to 7K+ daily?
gotta love a strong motor... with upgraded ecu
Old Sep 28, 2005 | 07:53 PM
xxrealmsxx's Avatar
i'll give you my motor if you want to put it in there........all 160k mi of it....
but as everyones said just maintain it and you are good to go.
Old Sep 29, 2005 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
I thought I blew the flucker today ... My tranny is dying, so it takes forever to shift out of 1st when it's started, took it 7k then it didnt shift, kept bouncing off the limiter .. I get to work and it dies .. Turns out, the tubing before the MAF came loose with all the engine flex ... ...whew.. simple 1 minute fix ...
Old Sep 29, 2005 | 12:31 PM
cefiro8701's Avatar
bet u were crapping bricks.
Old Sep 29, 2005 | 12:33 PM
NmexMAX's Avatar
dot dot dot ...
Until I popped my hood.
Old Sep 29, 2005 | 12:45 PM
scrhale's Avatar
Dude ... I want you to do a compression test on that motor. If it is still good then my Max needs to get more friendly with my best friend ... redline ... lol. I was always scared to let her rip. On top of that ... gas prices are killer.
Old Sep 29, 2005 | 12:49 PM
NmexMAX's Avatar
dot dot dot ...
Don't get friendly with redline unless you have a VIM ...
188-192 in between there last time I checked ..
Old Sep 29, 2005 | 12:58 PM
scrhale's Avatar
why not? Just because the power band dips at 5K doesn't mean anything. You are still making more power a 6.5 in 1 then you are in 2nd when it shifts and same with 2-3.
Old Sep 29, 2005 | 01:02 PM
NmexMAX's Avatar
dot dot dot ...
W/stock IM I can shift @ 6.5k or let it do it's own @ 6k, and get the same results.
From a dyno prespective, you're making~ the same HP (a bit more) but with a lot more torque once in 2nd.
Old Sep 29, 2005 | 03:29 PM
MDeezy's Avatar
ahhh . . It seems like all those bragged about visits to 7k+ daily are catching up with you
Must have been some hard engine flex to knock out the tubing before the maf.
Old Sep 29, 2005 | 03:32 PM
NmexMAX's Avatar
dot dot dot ...
Well, I don't have the support bracket for the stillen POP so it flops around like ... nevermind
Old Sep 29, 2005 | 03:34 PM
XeroX's Avatar
Hella internets
*Singin* "im da O-D-B as you can see!"
if you can get ahold of a 2k-2k1 motor, swap one of those in there...easy drop, and you get the VI...
Or you can hassle with the 3.5 swap, but thats ALOT more work...
Old Sep 29, 2005 | 03:35 PM
MDeezy's Avatar
I'm glad you didnt say it.
Old Sep 29, 2005 | 03:36 PM
Dubbya's Avatar
VK56 Inside
what he said
Old Sep 29, 2005 | 04:17 PM
killerVQ30DE's Avatar
quote "My tranny is dying" .. "took it to 7k" eek I'm sure that will fix the trans right up
Old Sep 29, 2005 | 05:33 PM
konak85's Avatar
i saw a cheap 3.0 somewhere and was gonna grab it, thats why i asked. Nothing wrong with mines. manual conv. is too expensive, and 3.5 is a PITA to do.
Old Sep 29, 2005 | 05:36 PM
NmexMAX's Avatar
dot dot dot ...
Engine is fine though
Just waiting for it(tranny) to die so I could 5MT it.
Old Sep 29, 2005 | 05:41 PM
MDeezy's Avatar
So thats why you take it to 7k+ daily. . . to encourage its death and birth it into a 5spd.
Old Sep 29, 2005 | 05:46 PM
NmexMAX's Avatar
dot dot dot ...
For the funfactor too ... once it warms up, it shifts fine.
Climbing up a hill at the top of 2nd is just
Old Sep 29, 2005 | 05:50 PM
MDeezy's Avatar
I can agree with that
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
