Looking for smooth Idle
Old Sep 28, 2005 | 10:53 PM
euser985's Avatar
my '98 maxima keeps shaking all time. not that hard of a shake, but still shakes a little bit when i'm on park,drive, or neutral. not that much on neutral, but still a little noticeable. i just got a tune-up so that can't be it. i know there could be many things that make the car shake, but just to narrow down on what it could be, it starts shaking after it warms up. meaning if i just started the car it wouldn't shake until it went well under 1000 rpm (when it starts it's usually a little over) and the temperature of the car went well over "C". please help me out, i don't want to feel any vibration on my brake pedal or my steering wheel when im idle on drive, neutral or park. thank you!
Old Sep 29, 2005 | 05:04 AM
deeloc's Avatar
start with cleaning your throttle body
http://www.motorvate.ca/mvp.php/517
then clean idle air contol valve
http://forums.maxima.org/showthread.php?t=254238
Old Sep 29, 2005 | 06:48 AM
brad kay
Right on. I, like many of us had this problem. Those pages are great. My idle is nice and smooth now.
Old Sep 29, 2005 | 01:00 PM
Jatan's Avatar
lol cleaned mine out last weekend (had high idle problems before that) and I'm having this problem since then. Idle is fine is neutral (~750) but goes down to 600-700 in drive and car starts hesitating - will have to check for air leaks tomorrow
Old Oct 4, 2005 | 11:56 AM
euser985's Avatar
im trying to clean my own throttle body as it guides you on:
but im having trouble performing the step on the 4th picture. which is removing the small black rubber hose. it doesn't remove that easily.i tried it as hard as i could. please tell me how i can disconnect it.
Old Oct 4, 2005 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
.... you posted this twice alerady
Use some nuts, don't be scared.
Old Oct 4, 2005 | 12:11 PM
euser985's Avatar
it looks like the hose is ripping because of how roughly i am trying to disconnect it. there must be some special tool to do it with
Old Oct 4, 2005 | 12:13 PM
NmexMAX's Avatar
dot dot dot ...
Slide the metal coupler ring off and it should slide off, I hope you did that first
Old Oct 4, 2005 | 12:16 PM
euser985's Avatar
there is no metal coupler ring on that one. its not the large one, it's the small one next to it im trying to disconnect and like i said there is no metal ring, but it still will not slide off
Old Oct 4, 2005 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, mine comes off easily, just keep pulling.
Old Oct 4, 2005 | 12:22 PM
Iron Scimitar's Avatar
Tha Snatcher
a good grounding kit should help w/ the idle i heard.
Old Oct 4, 2005 | 12:29 PM
NmexMAX's Avatar
dot dot dot ...
Or just clean the grounds on the LIM.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
