Codes 0303 & 0503, just checking...
Old Oct 2, 2005 | 10:04 AM
zachosz's Avatar
Before you start yelling at me, yes i know what the codes mean... My question is this, what are the chances of it being a short in the wiring, anyone had this happen before? I failed emmisions because my CEL was on at the time and I'll change the O2 sensors anyway, i'm just curious.
0303
Diagnostic Trouble Code 0303 indicates a problem with the front Oxygen Sensor on the left cylinder bank. The left bank is also called the front bank. It is cylinders 2,4,6. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
0503
Diagnostic Trouble Code 0503 indicates a problem with the front Oxygen Sensor on the right cylinder bank. The right bank is also called the rear bank. It is cylinders 1,3,5. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Old Oct 2, 2005 | 10:11 AM
MDeezy's Avatar
examine the wires if you think there is a short. More than likely there isnt.
Old Oct 2, 2005 | 10:16 AM
njmodi's Avatar
Do I get a tax break?
99.9% bad sensors, 0.1% chance it's a harness or wiring problem/
Old Oct 2, 2005 | 10:19 AM
Supermax95's Avatar
both sensors went bad at the same time?
Old Oct 2, 2005 | 12:42 PM
zachosz's Avatar
Ok that's what i thought... both sensors went bad within the last 2 months, not sure if it happened together.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
