How to pull apart 95/96 tails
Old Oct 3, 2005 | 08:53 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
Hey guys...
I was wondering if theres a write up, or someone that knows how to pull apart the 95/96 tail lights... The 97-99's are alot different than these so the write-ups for those dont help..
Thanks in advance,
Mike
Old Oct 3, 2005 | 08:56 PM
86maxima96's Avatar
I Broke OT
in the oven, but you do know you can't pull the orange part out, right? are you gonna DTM them?
Old Oct 3, 2005 | 09:03 PM
I'm not a newb...haha... I wanted more specific information from someone that has done this once before.... I could've gotten that answer from the 97-99 write ups... like what to do with the tabs that the 95/96 housings have??...Thanks though...
I have all clears that I just got in the mail that im going to red clear....
Mike
Old Oct 3, 2005 | 09:14 PM
maxspeed96's Avatar
Hey Mike, Let me know if you get a write up on this, I need them as well. Still waiting 4 mine (3 of them) to arrive. Thanx...Eddie
Old Oct 3, 2005 | 09:20 PM
Hey Eddie,
Yeah, I got them late tonight from UPS..
Good packaging... and they even came with bulbs!
I mean, the tail lights are pretty much like the 97-99's, except the 95-96 housings have 4 tabs holding the outer lense on...I'm just trying to figure out if theres any trick, or special thing I should do to ensure that I don't screw up these irreplacable lights!
Mike
Old Oct 3, 2005 | 09:24 PM
98maxon18s's Avatar
well its basically the same theory and technique in opening 95-96 as 97-99. its only once its open where the things change. Just take the tails off the car bring them inside. take out the bulbs and wiring. heat oven to 200 degrees and then bake for 10-13 minutes. do 1 at a time, because it takes a couple minutes once their out of the oven to seperate the plastic from the housing. once it was in the oven for 10-13 mins use oven mit to take it out and also to handle it with just 1, ur gunna need a free hand to use with a screw driver. then you take a flat screw driver between the housing and the plastic at the tabs and pull the tab up a lil bit then seperate a little bit the plastic from the housing, do it to all 4 tabs then work the flat head around the housing seperating it and pulling the plastic off, take ur time and be gentle. it will come off, just be nice.
Then once its off do your dirty work.
once your done put the plastic peice over the housing dont try and force it back on the glue prolly cooled down so it wont happen, just put it over top and bake in oven for like 7-9 mins to heat it back up, then push the plastic peice into the housing back to how it was. and hold it there for a little bit to make sure it goes in flush and the glue settles. Repeat for the other tail.
Old Oct 3, 2005 | 09:25 PM
maxspeed96's Avatar
I hear ya, Im almost scared to try to attempt this. Cause if we screw up, there goes $150. Ill keep looking as well 4 a write up, and let you know as well if I find one. Thanx again.
Old Oct 3, 2005 | 09:26 PM
Thanks for the info!
bump
Old Oct 3, 2005 | 09:29 PM
maxspeed96's Avatar
Haha, 98maxon 18s beat me to the post, thanx for the write up.
Old Oct 3, 2005 | 09:32 PM
98maxon18s's Avatar
for any other questions look here for the info
http://www.vqpower.com/v2/modules.ph...howpage&pid=66
Old Oct 3, 2005 | 09:37 PM
Hey Eddie,
I'm going to be doing this tomorrow evening. I'm going to try it on the stock tails first...Once I do that right i'm going to be doing the all clears.....
Mike
Thanks again 98maxon18's!!!
Old Oct 3, 2005 | 09:44 PM
86maxima96's Avatar
I Broke OT
ok, I see. sometimes you don't know what to expect with some of these 4th genners. sorry bout that! and good luck with these lights! if I wasn't a poor college student, I would be doin the same thing!
Old Oct 3, 2005 | 09:46 PM
98maxon18s's Avatar
No prob man, anytime i can help i will try my best.
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
