anyone have a stage 2 valve body....
Old Oct 4, 2005 | 07:54 AM
DcMaN's Avatar
Well basically i bought a car with a stage 2 valve body installed from jeff. But i think something is messing up. Lately it hasnt been hitting the gears like it should usually when it hits first gear i can feel it but sometimes i dont feel it at all. And sometimes when it does happen it feels like it gets stuck and it trys to downshift or something. I dunno its weird is it anything to worry about. Its the original tranny with 166k. Tranny flush every 15k. Fluid is clean.
Old Oct 4, 2005 | 07:56 AM
NmexMAX's Avatar
dot dot dot ...
Vague post
So it doesn't bang into gear like usual, meaning it "slips" more? Or
Old Oct 4, 2005 | 08:23 AM
Dubbya's Avatar
VK56 Inside
I have a stage 2, but do not see the problems you are. Its hard to diagnose auto trans problems via the net though.
Old Oct 4, 2005 | 08:27 AM
NmexMAX's Avatar
dot dot dot ...
Dubbya
I have a II.5, and sometimes is shifts, "softer" than normal, meaning my liver stays intact, and other times it bangs like an "N" drop while going from 1-2.
Old Oct 4, 2005 | 09:36 AM
C MAX's Avatar
Originally Posted by NmexMAX
Dubbya
i experience the same thing sometimes, it depends where the throttle is when the gears are shifting. maybe that is just how these work.
Old Oct 4, 2005 | 11:09 AM
Dubbya's Avatar
VK56 Inside
Yes. I noticed that when you accelorate aggresivelly and let off the gas it will shift hard (i.e. 1st to 2nd), but if you give a smooth acceloration it shifts with out the big bang effect.
Old Oct 4, 2005 | 11:23 AM
battle_zone's Avatar
I have a question about this valve body mod From what I understand it's only for automatics right. Is there a noticable difference after you do it and does it use more fuel?
Old Oct 4, 2005 | 11:24 AM
NmexMAX's Avatar
dot dot dot ...
autos only
difference in what?
No more used fuel.
Old Oct 4, 2005 | 11:55 AM
C MAX's Avatar
only for auto and yes you feel a difference its a harder crisper shift and it doesnt burn more fuel. basically it preserves your clutches from burning out from slippage during the changing of gears
Old Oct 4, 2005 | 05:38 PM
NightRider's Avatar
I have a stage 4...mine is only soft if I am soft on the pedal.
litch
123
Jan 4, 2024 07:01 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
sliptap
Sep 30, 2015 05:57 AM
