Bad crankshaft sensor?
Old Oct 4, 2005 | 09:41 AM
f550maranello2's Avatar
Has anybody had to replace the cranksensor thats located on the transmission? i checked it out last night and from what the 97maxima repair manual says its bad... now i do notice that the car is slow but i have no MIL light on or anything... im wondering if i should replace it or not to see if it will solve the problem..
Old Oct 4, 2005 | 09:44 AM
NmexMAX's Avatar
dot dot dot ...
If then what statment....
If-->
Then --->
How did you determine it being "bad"?
Old Oct 4, 2005 | 09:45 AM
chenzarino's Avatar
never had to replace it, but once during a hard shift the connector came loose and my car died right in the road. Couldnt figure out what it was for days. Note to everyone: Get a service manual and keep it in your car.
Old Oct 4, 2005 | 09:50 AM
keb1209's Avatar
I've had to replace both crank position sensors this year, each time one went bad my SES light came on. Also, I major had problems starting in both cases... which went away immediately following replacement.
Old Oct 4, 2005 | 09:53 AM
If-->
Then --->
Cuz like i said the car has a big power loss... i looked in the book and checked the timing which looks like its off by at least 15 degrees.. then i checked both the cranksensors and the cam sensor all of them looked ok.. but the last sensor gave me 12volts across terminals 2&3 insted of 5 volts.. so i dont know weather to replace it or not...
Old Oct 4, 2005 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
What would determine your timing to be off?
Maybe you have a bad KS ...
Unless you changed your timing chain and/or water pump, then the timing shouldn't be that bad. What's off, BTDC or TDC, ignition or cam timing? Why can't you verify using an OBD compatiable tool?
Old Oct 4, 2005 | 10:08 AM
i used a timing light.. unplugged the tps sensor and checked it warmed up and cooled down... the BTDC is at like 35 not 15... i dont have access to a obd scantool to check it...
Old Oct 4, 2005 | 02:02 PM
gabex's Avatar
If i had some knowledge to share I would.. however I do have a brand new Crankshaft Sensor (REF) in box sitting in my apartment I could get rid of if you needed it.. it was a special order and it took too long to get to my house, my car was fixed before it arrived
Old Oct 8, 2005 | 07:33 AM
mikeg75's Avatar
I had to replace my Crankshaft Position Sensor 3 years ago, b/c the car was having rough starts, and then one cold Christmas Eve, wouldn't start at all. However, I had taken it first to the dealer and then to my mechanic b/c of the Check Engine Light, and in between, put in a new battery, before they finally replaced that part. I felt so ripped off when 2 times in a row, I took the car in and all they did was reset the computer, and then the light came back on, b/c each time it was 80 bucks or so.
What does the Crankshaft Position Sensor do, by the way?
Old Oct 8, 2005 | 01:29 PM
ctownmax's Avatar
ok... off topic.. i bought a 95 5speed just the other week and it has been starting really crappy lately, and then the check engine light came on, i checked the code, and it was the cam sensor and the knock sensor, so i replaced the cam sensor today... no change in the way my car has been starting, and it is still throwing a bad cam sensor code.... help???
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
ballerchris510
Sep 11, 2015 05:29 PM
