exuast size
Old 10-05-2005, 04:44 PM
AGRECORDS
exuast size
what size exuast pipe do you think would be better..... 2.5 or 3.0 inches?
Old 10-05-2005, 04:51 PM
sonicrunch's Avatar
2.5 for you
sonicrunch is offline
Old 10-05-2005, 04:56 PM
joosdawg's Avatar
lol cmon man you make some of the stupidest posts that can be found by looking around... no offernse to you but why are you asking. if your still doing that turbo project do 3" otherwise go 2.5" heck even 2.25" piping if just fine for NA -Ryan
joosdawg is offline
Old 10-05-2005, 05:03 PM
AGRECORDS
well im going to turbonetics for my setup...but for now i need a new exaust cause mine is going... what im asking for a N/A (right now) 2.5 or 3.0 better? i know a 3.0 for turbo all day... but any performance difference on an N/A?
Old 10-05-2005, 05:06 PM
Minister of Silly Walks
mzmtg's Avatar
With exhausts, turbos, port jobs, and chicks; bigger is ALWAYS better.
mzmtg is offline
Old 10-05-2005, 05:07 PM
joosdawg's Avatar
anything over 2.5" on NA looses volocity and hurts lowend
joosdawg is offline
Old 10-05-2005, 05:09 PM
AGRECORDS
thanks for the knowledge joosdawg.
Old 10-05-2005, 05:10 PM
zander's Avatar
wouldn't you lose some low end with a giant exhaust? 3 inches seems a little much for NA. Get a 2.5 so when (if) you go turbo the exhaust will work well.
zander is offline
eckohb's Avatar
yeah, i wouldn't recommend going higher than 2.5 for NA. 2.5 mandrel or crush bent. 3" for your "turbo set up".
eckohb is offline
Old 10-05-2005, 06:04 PM
Team Ramrod
lilaclucymaxima's Avatar
3742161
lilaclucymaxima is offline
Old 10-05-2005, 06:19 PM
dot dot dot ...
NmexMAX's Avatar
I still have 1-7/8" on my 03 .
NmexMAX is offline
Old 10-05-2005, 06:46 PM
Puppetmaster's Avatar
That's why you're only getting 233 on em rollers...
Puppetmaster is offline
Old 10-05-2005, 06:47 PM
2 Da Max's Avatar
get the 5inch APEX N1 Turbo exhaust KIDD!! that shiet makes crazzy powa
stay with 2.5
2 Da Max is offline
Old 10-05-2005, 07:00 PM
dot dot dot ...
NmexMAX's Avatar
I know
It's probably my fatty stock wheels holding me back ...
NmexMAX is offline
Old 10-05-2005, 07:07 PM
brad kay
werd. gotta keep some back-pressure there hass lol.
Old 10-05-2005, 07:15 PM
dot dot dot ...
NmexMAX's Avatar
Oh no you di'int ..
But there is use of the word 'backpressure'.
Backpressure is a terrible word that shows a lack of understanding of how a tuned exhaust system really works. The correct terminology is 'Exhuast Gas Velocity' which you do want a certain amount of. And although some of those guys think you have a poorly setup exhaust, I choose to dissagree without solid proof and taking into account the future path in which you intend to take your car.
NmexMAX is offline
Old 10-05-2005, 07:22 PM
'Trynna' is not a word
mtrai760's Avatar
Wow, this thread is ready for teh
mtrai760 is offline
Old 10-05-2005, 07:28 PM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 10-05-2005, 07:32 PM
See also: http://www.magnaflow.com/05news/magazine/05sportc.asp
BACKPRESSURE = TORQUE?
An old hot-rodder's tall tale: Engines need some backpressure to work properly and make torque. That is not true. What engines need is low backpressure, but high exhaust stream velocity. A fast-moving but free-flowing gas column in the exhaust helps create a rarefaction or a negative pressure wave behind the exhaust valve as it opens. This vacuum helps scavenge the cylinder of exhaust gas faster and more thoroughly with less pumping losses. An exhaust pipe that is too big in diameter has low backpressure but lower velocity. The low velocity reduces the effectiveness of this scavenging effect, which has the greatest impact on low-end torque.
IBTL!
Old 10-05-2005, 07:45 PM
brad kay
yeah.. i was just kind of taking it to extreme measures for the sake of making a point? lol i dono i need to denote sarcasm better with the things i type. However, my point was that at a certain point you lose all backpressure and that is not a good thing. You might want your backpressure to be low, but you certainly need to have some. a 3'' pipe would not bring you to this critical area necessarily, but that was just what i was getting at in general.
IBTL![/QUOTE]
Old 10-05-2005, 08:02 PM
sunten1
unless your going boost don't even both stick with 2.5in
Old 10-06-2005, 07:48 PM
the_3d_man's Avatar
I don't know about you but I have the 6" exhaust in my max... got me 100HP
oh yeah!!
the_3d_man is offline
Old 10-06-2005, 10:55 PM
ImmaSquashYou's Avatar
2.5 in exhaust provides enough backpressure for the N/A cars. However with a turbo setup, a 3 in. is recommended for the power its going to put out. Less restrictive (less back pressure) will gain your high end speed. if you have all this money to blow, then get a 2.5 in, n then get a 3 in when you have your turbo. Just make sure you read up all about turbos. I was going to do it to my car, then i realized how much of a pain it will be n i wouldn't have time to take care of the turbo. If youre going to take it to a shop everytime it needs to be taken care of, just remember that you're going to spend a lot of money on labor. Remember a turbo needs to be tuned and looked after time to time. Make sure that you are willing to dish out a wad of cash even AFTER having the turbo. There are alot of things that are needed, not just the turbo kit....
ImmaSquashYou is offline
Old 10-06-2005, 11:04 PM
dot dot dot ...
NmexMAX's Avatar
Enough backpressure is a must for low end
NmexMAX is offline
Old 10-07-2005, 03:50 AM
LeX
Nissan by Nature
LeX's Avatar
it's nothing to do with backpressure it's exhaust velocity
LeX is offline
Old 10-07-2005, 05:06 AM
I think he was being sarcastic....
Miket2006
03-01-2021 03:55 AM
RIPTIDER
Wheels/Tires
01-31-2016 07:39 AM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: exuast size
