anyway to unfog 97 headlights?
Old Oct 9, 2005 | 08:22 AM
DcMaN's Avatar
Is their anyway to unfog the headlights?? I cant even see at night with the lights on its pretty bad.
Old Oct 9, 2005 | 08:40 AM
Mrbizness1's Avatar
If there is mosture in the headlamps you can drill a small pinhole on the bottom of the unit to let it out.
Old Oct 9, 2005 | 08:48 AM
achebee4you's Avatar
well bake em seperate em, sand em and polish
Old Oct 9, 2005 | 09:22 AM
99Automagic
Wouldn't that also let moisture IN?
Anyways, check this thread out.
http://forums.maxima.org/showthread.php?t=322999
Lots of info on polishing headlights.
Old Oct 9, 2005 | 11:09 AM
Mrbizness1's Avatar
You can sand or polish it out if the lense is plastic.
I have used Mcguires on my van with plastic lenses, after a few applications it was much improved.
I drilled a small pinhole on an Olds with good results.
Old Oct 9, 2005 | 12:50 PM
13r1an's Avatar
thanks, this was really helpful...
Old Oct 9, 2005 | 01:43 PM
4thgenx42's Avatar
Just get a set of 99' headlights...
Old Oct 9, 2005 | 01:45 PM
PandaXpress's Avatar
dude..bake the headlight..or heat gun it open...then..take the lens and some brake fluid..and wipe the fliud gently throughout the entire inside of the lens (if the fogging is on the inside) and it will clear right up...if its on the outside.you dont have to bake it or use a heat gun..just carefully clean it with brake fluid.
Old Oct 9, 2005 | 03:10 PM
ny96max's Avatar
yep... just buy new ones!
Ant
Old Oct 9, 2005 | 03:50 PM
goldtooth's Avatar
EXTREMELY carefully, cuz if u get brake fluid on paint....then paint go bye bye....lol
Old Oct 9, 2005 | 08:53 PM
the_3d_man's Avatar
why brake fluid?
Anything that might be more suited for this purpose?
I guess I will have to try it...
Old Oct 10, 2005 | 12:25 AM
swedeinfiniti's Avatar
On my 99 i30 it looks like the entire plastic is cloudy. Is this a surface issue or does it go throughout the entire piece of plastic?
Old Oct 10, 2005 | 06:39 AM
EXTREMELY CAREFULLY.....I would take out the headlight completely if i were you.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
