springs creak
Old Oct 9, 2005 | 12:10 PM
AlexJones's Avatar
springs creak
just installed my new eibach lowering springs. i love the new look and the handling but when i am breaking they tend to creak. what can i do to fix this?
Old Oct 9, 2005 | 12:49 PM
njmaxseltd's Avatar
They might not be seated evenly or the clocking of the upper perch is wrong.
Old Oct 9, 2005 | 01:34 PM
86maxima96's Avatar
I Broke OT
did you remove the rubber coil wrap from the old springs and put in on the Eibachs? Or did they come with that? I'm assuming you are saying the fronts creak when you break because they would compress. If you don't have the coil wrap on the bottom and top coil, you should. It may help, because those are the parts of the spring that actually compress enough to cause contact a.k.a. squeaking/creaking.
Old Oct 9, 2005 | 03:32 PM
AlexJones's Avatar
i put the wrap on there. and i was extra careful to line up the springs correctly, i might not have it perfect tho, any other suggestions?
Old Oct 9, 2005 | 04:03 PM
njmaxseltd's Avatar
OK, are you sure it's the springs creaking?
Maybe the control arm bushings aren't happy with the new ride height.
Also checked the sway bar end link bushings or even the sway bar's main bushings.
What struts did you use? How did the strut mounts look? Is everything tight?
Did you make the word OUT which is stamped on the top of the upper spring perch face outwards which lines up with the sturts lower mounting flange?
Old Oct 9, 2005 | 05:03 PM
browne's Avatar
wait 2 weeks.. it will go away. i almost put back my stocks cuz i couldnt stand the creaking but it went away.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
