0705 code, EVAP
Old Oct 9, 2005 | 01:26 PM
thefed's Avatar
0705 code, EVAP
This code can be caused by MANY things I read. What are the most common?
I THINK I had this code 6 moths ago. I went to the canister, which I think is behind the passenger side, rear wheel. I removed an electronic valve back there, used wd-40 on it because it was stuck, hooked it up to a 12 v power source to un-stick it, and replaced it.
Does that sound liek a possibility again? What was that piece I removed...I may just buy another one if I knwo its name....
Other ideas? (its not the gas cap)
Old Oct 9, 2005 | 02:03 PM
l3ftonm3's Avatar
the valve could be clogged also, it has 3 nipples on it and should be white thats how mine was you can check that make sure its not dirty. Also check the electrical connections again. I had this code and none of the above worked so ended up getting a new cansiter too the code went away for a week was able to pass inspections now its back on again for some damn reason it goes on and off so id say dont worry about it unless you need to pass an inspection.
Old Oct 9, 2005 | 02:27 PM
96ItaliaSE's Avatar
il massimi bassi
i had 07 05.... 99% of the time its the vent control valve...even if its not throwing a code for it...fix it asap as it will hinder your gas mileage
Old Oct 9, 2005 | 05:24 PM
randy021186's Avatar
I HATE THE F"ING CODE ....i have started aleast 12 threads here and other .orgs trying to find that problem....it started right after i did a TB Cleaning and sprayed some stuff in the flop, and as you can see the intake is connected directly the valves and then the canister ...the code came on once in a week then 2 in a month then everytime i filler her up.....finally i got it fixed....Knock on wood...i just found a friend that crashed his car, gave almost nothing for the part and the problem has been fix for about a month now, i replace the canister and any valve i can find back there.........
Old Oct 9, 2005 | 05:39 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
where is the vent control valve located? when you say fix it, do you mean replace it or does it get cloged come how?
I have this code right now and have no idea what it is.
Old Oct 9, 2005 | 05:42 PM
4DRSpeed's Avatar
Project Ruby......
I have this code as well. Along with a left front O2 dead.
Old Oct 9, 2005 | 05:49 PM
THT's Avatar
THT
Throbbing member
Can also be a poorly sealing gas cap.
Old Oct 10, 2005 | 11:03 AM
thefed's Avatar
is this VENT CONTROL VALVE the thing I referred to in my original post?
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
