Interesting part change from cali-fed
Old Oct 10, 2005 | 12:24 PM
|Bijan|'s Avatar
UCF Lexus
Some of you may or may not know this....I didnt know till I took it off
But, the lower intake plenum on a cali-spec has butterfly fins/valves (whatever) - controlled by the big apple size vacuum canister type thing right in front of the TB.
Well, we had a spare, but it was a FED-spec plenum. We switched it out, along w/ a new gasket.....and everything works better. It had a VERY hesitant cold idel before-hand....and now it's fixed.
We put a small bolt in the hose that fed to the pressure canister thing. No codes....yet?
Anyone else done this?
Old Oct 10, 2005 | 02:05 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Huh? Is this for the oovi?
Old Oct 10, 2005 | 02:19 PM
1FSTMAX's Avatar
yes i know.. did he remove the front precat too? that would be better than taking the swirl control system out..
Old Oct 10, 2005 | 03:11 PM
RA030726's Avatar
I'm nutty for Nissans
you should have dynoed the car before and after to dispell the myth of the butterfiles. some think they cause a restiction and rob power.
any noticable difference in driving, or is it too early to tell.
Old Oct 10, 2005 | 03:13 PM
slimer's Avatar
I'm still in the dark.
Old Oct 10, 2005 | 04:17 PM
1FSTMAX's Avatar
i have only seen the butterflies open and close when the engine is cold. When the engine is hot, they stay open all the time.
Old Oct 10, 2005 | 06:12 PM
RA030726's Avatar
ok, i remember reading that. but could just them being there hurt flow?
Old Oct 10, 2005 | 06:46 PM
1FSTMAX's Avatar
i doubt it..
if anything the front pre cat would cause some power loss..
Old Oct 10, 2005 | 07:17 PM
Zack342's Avatar
This is all true
I love my butterfiles i have a bunch.
Old Oct 10, 2005 | 07:31 PM
RA030726's Avatar
the front precat really doesnt do much power wise. the area under the curve is similar with no peak gains, acctually a loss in the peak tq. gains are minimal from 4k-6krpm. not worth the time.
http://www.desertpearlmax2.homestead.com/Fed_YPipe.html
look at the low end loss! especially the tq. may as well keep the precat. hell the stock y pipe made more low end torque.
Old Oct 10, 2005 | 09:15 PM
1FSTMAX's Avatar
the butt dyno on my end tells a different story.. but i did replace my knock sensor, did the fed spec manifold, and replaced my stillen y pipe which had a collapsed flex section with my cattman..
Old Oct 10, 2005 | 10:29 PM
|Bijan|'s Avatar
UCF Lexus
thats next on his list
he got a straight pipe this past weekend...(vortechpower)
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Team STILLEN
Aug 10, 2015 04:29 PM
RealityCheck
Aug 5, 2015 06:18 AM
