Steering wheel jerks (power steering) when cold..
Old Oct 10, 2005 | 05:52 PM
thefed's Avatar
Right when I start my car up, the wheel does not turn freely. It jerks when turning, or shakes. Once I warm it up, its okay most of the time.
Fluid is okay, no leaks
Old Oct 10, 2005 | 05:54 PM
tavarish's Avatar
fwd gone rwd cr00
mine does this as well. try replacing the belt, like i'm planning on doing this weekend.
Old Oct 15, 2005 | 07:46 PM
thefed's Avatar
Big Bump....
Old Oct 15, 2005 | 07:59 PM
f550maranello2's Avatar
try adjusting your belt i had the same problem on a different car..
Old Oct 15, 2005 | 10:27 PM
gassian's Avatar
today i heard some popping noise turning the steering wheel....is this normal?
i drove it around and it is fine ...didn't notice anything
Old Oct 16, 2005 | 07:03 AM
Jatan's Avatar
Same problem in the winter - hard to get out of a parking spot. Haven't really looked into it...
Old Oct 17, 2005 | 06:13 AM
thefed's Avatar
I'm thinking it may be the belt. Today, i noticed it squeal a bit during my commute to work.
How would I go about adjusting it? Is the a walkthru or anything in the sticky's?
Old Oct 18, 2005 | 07:37 AM
thefed's Avatar
BIG BUMP in the name of being broke...
Old Oct 18, 2005 | 08:14 AM
thefed's Avatar
SO, I had some guys take a looi @ it for me while I was running some errands for work. the garage I had look @ it says indeed it WAS the belt, and they tightened it, warnign that it will do it again. They say the belt is stretched and the other probably is as well.
SO, for 80.00 should I have them do it, or should I try. I'm relatively mechanically inclined....but it looks like a tight spot to get into. How much are just the belts? I cant find them at AutoZone or anything...
Old Oct 18, 2005 | 08:20 AM
LudeAEM's Avatar
i believe no service manaul tells you to change the PS fluid but i did the other week with some synthetic ATF (dextron III). I used synthetic because it has a better temp range. Look in the fluid and lubricant section for help. It could also be the belt too.
Old Oct 18, 2005 | 08:33 AM
thefed's Avatar
Well, I found OEM belts for 30 bucks for both. SO, is 50 a good deal for them to do the labor? I read soemwhere how to do the job, and it seems it might take me 1.5 hrs.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
coasterswim
Sep 2, 2015 07:43 AM
