To the Gauge Cluster Gurus
Old Oct 11, 2005 | 02:05 PM
Linkage23's Avatar
I remember someone owning a 95-96 Maxima (which have the analog odometer) convert to a 97-99 guage cluster and was abelt o dial int he correct miles and whatnot....Can someone instruct me where to go....the search is wokring properly for me...Thank you in advance!
-Ryan-
Old Oct 12, 2005 | 11:33 AM
Linkage23's Avatar
Can anyone help me?! My RPM gauge in my Maxima is dead and have just purchased a 98 gauge cluster to replace the dead one....It would be valuable to me to have a odometer. So, if ANYONE has any info on what to do, besides buy the correct gauge cluster, I would greatly appreciate that!
-Lieb-
Old Oct 12, 2005 | 11:57 AM
motocross416's Avatar
I tried searching and it has been done. The guys name is something along the line of jnotofthisworld. It sounds like you have to splice all the wires together from the digital to analog cluster. I couldn't find a write up on it though
Old Oct 17, 2005 | 04:50 PM
Linkage23's Avatar
That name is not correct but thanks...can anyone remember what the actual name is?! Thanks again...
Old Oct 17, 2005 | 07:40 PM
Tim96I30t's Avatar
U can take it apart and use the rpm gauge from the 98( the insides) and take apart the older one and they should be the same. The only difference inside I believe is the speedo gauge w/ digital other than that i think they are the same.
Old Oct 17, 2005 | 07:53 PM
RA030726's Avatar
I'm nutty for Nissans
negative. I have had both mine side by side and everything is different on the inside.
Joe, 98seblackmax did the swap. he used the plugs from the 98-99 gauges with the gauges. he swapped every wire and used a square wave generator to simulate the speed sensor. he ran the odometer for months to get it right. which you can only add miles, no rolling back. oh and you need to splice constant voltage to keep the trip meters from reseting.
Old Oct 17, 2005 | 08:24 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I think I have the harness. I have a 98 and bought a 98 and the person that I got it from included the harness. PM me for an offer.
Old Oct 17, 2005 | 10:01 PM
mendon99's Avatar
tastey wheat
, it was pinned at 140 mph for a month straight, lol. he said it was a lot of wiring, and motocross, jnotofthisworld is his aim name.
Old Oct 18, 2005 | 01:13 AM
Linkage23's Avatar
Thank you very much for the help...it sounds as if I'm gonna have to contimplate this swap now...thanks!
-Lieb-
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
toyoking
Sep 16, 2015 07:05 AM
Max139617
Sep 6, 2015 06:02 PM
