Pulling to the left after alignment?
Old Oct 11, 2005 | 07:35 PM
MaximusAureleas's Avatar
I had an alignment done a while back at a Firestone. At the time, my steering wheel had went off-center out of the blue (strangely enough after I rotated my tires). The steering is straight now, but I still notice the car does pull to the left consistently when I let go of the wheel. Is this an issue of a crappy alignment job, or are there other factors that contribute to pulling? BTW, both front tires do have even tread and inflation, so I dont think its a tire pull of any kind.
Old Oct 12, 2005 | 04:58 AM
njmaxseltd's Avatar
Post your alignment specs.
You could also have radial pull from one of the tires you just put up front. Rotate them back and see if it stops. A simple rotation of tires should have no effect on your alignemnt. The fact that your steering wheel went off center when you rotated your tires points to a tire problem.
Old Oct 12, 2005 | 06:10 AM
Mxrider52's Avatar
I support for what?
If you rotated your tires after you got the alignment done then it is a tire off balance problem
Old Oct 12, 2005 | 07:50 AM
chenzarino's Avatar
CHeck tire pressure too it can cause pulling to one side.
Old Oct 12, 2005 | 08:07 AM
mzmtg's Avatar
Minister of Silly Walks
They may have only adjusted the toe. Camber isn't officially adjustable on our cars, but a good tech will juggle the suspension bolts to at least get it even side-to-side. Even if the toe is correct, uneven camber can cause a pull.
Old Oct 12, 2005 | 10:23 AM
InsneDrmr's Avatar
Any time I have ever gotten an alignment it was never good...it always pulled to one side or the other. I gave up. Now I just do it when its really needed.
Old Oct 12, 2005 | 11:24 AM
Haibert88's Avatar
The reason it sometimes will pull even after alignment is because your tires will wear a certain way before the alingment and when it's done the inproper wear will cause a SMALL amount of pull to one side for a while...
Miket2006
Mar 1, 2021 03:55 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
zmcneely13
Sep 26, 2015 02:26 PM
