Seat Shifting = Annoying
Old Oct 12, 2005 | 11:31 PM
eLMo's Avatar
Anyway we have a cooler and my mom told me to guy one of those big bottles for the cooler. I went and got it and I put it behind my seat and in order for it not to move I pushed the seat into it. Now since then when I stop at a stop sign the seat shifts foward and when I go it shifts back. I have electric seats on it I dunno how that happens.
Old Oct 14, 2005 | 12:03 AM
eLMo's Avatar
Can anyone help me fix it please?
Old Oct 14, 2005 | 06:05 AM
kbmaxima's Avatar
bump because my seats are creaking bc of the springs inside. everytime i sit <creeeaak>
as for the shifting, have you checked all the bolts mounting the seat bracket to the floorboard?
Old Oct 14, 2005 | 07:39 AM
lilaclucymaxima's Avatar
Team Ramrod
If the bolts bolted to the floorboard were the problem, his seat would come right out of the floor.
Old Oct 14, 2005 | 08:15 AM
MaxKlinger's Avatar
Sounds like the seats are shifting on the rails. If you push/pull on the front seat from the back can you see/feel the front one move? Do the rails move?
You may have to take the seat out and look from underneath. You my have damaged the gears that drive the power seat adjustment. Try an inspection mirror first.
Never force your seat motors.
Old Oct 14, 2005 | 12:43 PM
96blackmaxSE's Avatar
boost me.....
this exact thing happened to me when i had my jeep...
the creeak sound you hear is the metal springs rubbing with something else metal...
in my jeep i had someone sit in the seat as i looked under the seat to see where it was coming from...i saw the spring that was loose and rubbing with the seat bracket when i sat down in the seat..
what i did to fix it was...i simply jammed a wad of paper in between the loose spring and seat frame and taada..
Old Oct 14, 2005 | 02:38 PM
FormorAccordMan's Avatar
kbmax-mine did the same thing. It wsas the lumbar. I pried off the back panel- CARFULLY- ( you can seriously screw up the panel if you are rough with it. Feel around with a large serving fork until you feel the locking pins and once you get all 4 of them, I THINK, pull the panel in a downward motioin as there are tabs on the top. I sprayed mine with wd 40 and have not have a problem since.
Old Oct 14, 2005 | 03:21 PM
I30tMikeD's Avatar
I had to eventually replace my rails because of the same problem. it will just get worse
Old Oct 14, 2005 | 04:08 PM
RockfordMax's Avatar
Back from the dead
not to mention its unsafe. you get in a frontal accident and ur legs are broken. front seat sliding you into the steering column never good :0
Old Oct 14, 2005 | 04:16 PM
DR-Max's Avatar
That is what car trunks are for.
Originally Posted by eLMo
Anyway we have a cooler and my mom told me to guy one of those big bottles for the cooler...
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
mpbclutch33
Dec 26, 2015 11:11 AM
hayne
Oct 5, 2015 11:53 AM
