Missfiring
Old Oct 13, 2005 | 10:56 AM
tigerxp17's Avatar
Missfiring
Cylinder #3 is missfiring. Which one is that one exactly?
I understand that i could be the plug or the coil...any other suggestions?
Where can i get the coils for a cheap price, if i need to change it???
Old Oct 13, 2005 | 11:01 AM
99SEmatic's Avatar
I believe #3 is the center one on the side facing the firwall. Anyone out there please correct me if I'm wrong as I am not 100% sure.
I would suggest replacing the spark plugs but if it's throwing a code, my guess would be that the coil may be bad. I believe 99's are notorious for having coil problems.
Old Oct 13, 2005 | 11:17 AM
Jatan's Avatar
Most likely coil pack
Old Oct 13, 2005 | 11:58 AM
MDeezy's Avatar
when were plugs last changed?
check coil pack with a multi meter.
If those two arent the cause it could be an injector.
Old Oct 13, 2005 | 01:19 PM
Chapman99SE's Avatar
happened to me last week on my #2 cylinder
if you dont have a multi-meter you can switch the coil with that of a different cylinder and see if the ECU coughs up a code for that cyl. which would prove the coil is the problem
ballerchris510
Sep 10, 2015 09:35 PM
coolsun
36
Oct 5, 2009 06:53 AM
maxultra
22
Dec 12, 2006 05:40 PM
y_boy100
Jun 9, 2006 06:58 AM
darklegend06
Mar 13, 2006 10:32 AM
