Cheveron/techron
Old Oct 13, 2005 | 03:55 PM
tuko's Avatar
Cheveron/techron
for the first time in my life I tried some that chevron/techron fuel injector
cleaner and I have to say, it works pretty good. Now the engine feels so
much smoother.
do anybody have knowledge of other stuff to put in our cars, something
for performance and/or maintenace.
Old Oct 13, 2005 | 04:11 PM
mtrai760's Avatar
'Trynna' is not a word
try zmax and slick50
Old Oct 13, 2005 | 04:12 PM
NmexMAX's Avatar
dot dot dot ...
Who uses additives ...
Just use toulene
Old Oct 13, 2005 | 04:30 PM
opm45's Avatar
Seafoam or Lucas Oil additive
Old Oct 14, 2005 | 12:47 PM
kcryan's Avatar
Techron is the best OTC additive for gas, dont try zmax or slick 50, both are no nos, also no lucas oil....
Old Oct 15, 2005 | 02:31 AM
nosispower's Avatar
Zmax is getting sued because their additives are basically alcohol that temporarily give you a little extra power at the expense of eating your engine up. Slick 50 also is crap because its teflon injection doesn't work apparently, unless it's chemically blended to the engine walls.
Old Oct 15, 2005 | 08:32 AM
kcryan's Avatar
Not to mention that in a few hundred miles z-max turns into hydrochloric acid, not somthing i want in my engine, plus z-max is way to thing, whereas i thing slick 50 is to thick, althouth before i knew what i was doing i have used both of these but not both on this car, thankfully.
Old Oct 15, 2005 | 09:22 AM
rocco5446's Avatar
Actually, I believe Zmax is basically tinted mineral oil, but regardless of what it is, it aint good.
Old Oct 16, 2005 | 11:19 AM
cnenov's Avatar
dont forget to change your fuel filter
the chemicals in the additive are too strong and they eat up the filter ellement which can potentially clog your fuel injectors
just fro your info - im not saying your car is gonna break down for sure tomorrow, just alittle preventive maintanance never hurt nobody
also about other additives - the only thing I use is an engine flush every year or so (to get all the biuldup from inside the engine) and no other crap that stays in your engine and you are not sure whether it works or not and what exactly it does to your engine. look at all the cars with 200,000mi+ that run just fine on regular oil changes. as for me - I use Mobil1 synthetic oil
Old Oct 16, 2005 | 06:40 PM
kcryan's Avatar
no need to engine flush with Mobil-1, actually its not a good idea, and if you really feel it is necessary try doing it with LC or Auto-rx, they are not as tough on the rubber in your engine.
Old Oct 16, 2005 | 06:57 PM
cnenov's Avatar
i meant to flush the engine. and then that I use Mobil1 as the oil of choice for my car.
