Damn groaning brakes again!
So my left rear wheel has started to groan when the brakes are applied , but only in reverse! I sprayed some brake cleaner in there and it silenced it...for about an hour. What the hell could be causing it?
BTW, the calipers were replaced as well as a new ebrake cable about a year ago. The pads have about 1/3 of the meat on them.
My rear brakes moan and groan when backing up the first time I start up in the morning, especially when it is damp outside. As soon as the brakes warm-up, everything is fine. I had a corvette years ago that did the same thing. I was told that the noise is just a resonant vibration of the pads, more of an irritant than anything else. The pads on my Max are only about 6 months old, and as long as the brakes don't squeal and squeak going forward like they used to, I am happy.
I have the same problem, and only when backing up with the brakes applied...its embarassing because it is so loud when it happens. I just replaced my rear pads and clips with genuine nissan parts from the dealer - and that's actually when the problem started. I thought about replacing rotors but I'd like to find out first if replacing rotors resolved this for anyone else.
OK I'll say it again....Run, dont walk to NISSAN and get the *updated* rear brake pad clips and use ceramic brake pads. These updated spring clips keep your pads from resting on your rotors. They look nothing like the original clips. Check out the TSB's. I couldn't stand this groaning noise. So far 1 year and ZERO noises when backing out of my driveway.
TSB#NTB99-031b
Spring Retainer Kit P/N: 440834U025
It worked for me. YMMV
TSB#NTB99-031b
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
