digital tach. help!?
Old Oct 15, 2005 | 03:14 PM
matts95max's Avatar
SO i installed my new gauge pod and one of the gauges was a digital tach. Does anyone know where to hook up to to get a tach reading from?
Old Oct 15, 2005 | 03:15 PM
MDeezy's Avatar
you'd need to get a signal from either a coil pack or behind the guage cluster (I believe green wire)
Old Oct 15, 2005 | 03:39 PM
pmohr's Avatar
No more Maximas...
It should be the white/green striped wire coming from the ECU, or the green (?) wire attached to the back of the cluster, most likely directly behind the tach.
EDIT: Should be three screws behind the cluster, labeled GND, IGN, and TAM. TAM is the tach signal wire.
Old Oct 15, 2005 | 04:10 PM
matts95max's Avatar
Thanks guys ill try it!
Old Oct 15, 2005 | 05:13 PM
matts95max's Avatar
so the green wire that are plugging into the cluster didnt work, where is the coil pack I can run it to? and where is the ecu?
Old Oct 16, 2005 | 11:06 AM
matts95max's Avatar
Bizzzumpp!!!
Old Oct 16, 2005 | 03:38 PM
EugThinks's Avatar
Free bump... did you check a Haynes or Chilton manual? I think they've got wiring diagrams and such. Sorry I can't help, I'm a newb.
Old Oct 16, 2005 | 07:32 PM
matts95max's Avatar
I have one but cant find it. any help is welcome
Old Oct 16, 2005 | 10:56 PM
joosdawg's Avatar
use the ecu its real easy just pop off the cover right on the passenger sides left foot, use a 10mm to take the harness off the ecu, take a flathead and undo the corners to the clear plastic casing and search on the lefthand side of the harness for a white wire with a green stripe and use a quick connect on it then run that wire through the center section behind the radio, ziptie it to teh other crap under the steering wheel, then take coat hanger with teh pillar off and stick it through. Tape the wire to the end of the hanger and pull it up then attach to the gauges wiring and be done. Hope that helped .
-Ryan
Old Oct 17, 2005 | 01:30 PM
matts95max's Avatar
well is there more than one wire with green and white on it? I did that to one of them, but I got no reedings..
Old Oct 17, 2005 | 02:58 PM
joosdawg's Avatar
its right there
Old Oct 17, 2005 | 03:01 PM
joosdawg's Avatar
it should be the only white wire with a green stripe. the others should have differnt color stripes.
Old Oct 17, 2005 | 03:14 PM
matts95max's Avatar
joosdawg I couldnt open that web page ill try the white and green wire I havent tried yet and get back to yall thanks
Old Oct 17, 2005 | 06:33 PM
joosdawg's Avatar
when you say it like that theres more than one white and green. MAKE SURE its white with green stripe and if your looking at the ECU from the passenger side then its more twords the upper lefthand side of the wire bunch, your gonna have to dig a little bit.
there it is, it says green on there but again its white with small green stripe on it
Old Oct 18, 2005 | 07:38 AM
matts95max's Avatar
ok I tried that one but got no signal so im assuming that it is the gauge now..thanks for the help tho!
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
HOOVERQ
Feb 3, 2001 12:36 PM
