Electrical Problem...Please Help!
Old Oct 17, 2005 | 06:15 PM
MystA RavE's Avatar
I have 2 15" under dash neons directly connected to my cigarette lighter wire. They are also grounded to the ground wire in the cigarette adapter. Last week, I got into the car and nothing was working, no cigarette lighter, no lights. I changed the fuse and then the cigarette lighter started to work and only one of the neons works. I plugged in my cell phone car charger and it worked for a little bit. I took it out and put it in again but the fuse in the charger blew. I have no idea whats going on...any thoughts?
Old Oct 17, 2005 | 06:17 PM
njmaxseltd's Avatar
Difibulation modulation........ Maybe it's a tank of bad gas...
Go over your wiring and I'm sure you'll find the problem.
Old Oct 17, 2005 | 07:19 PM
MystA RavE's Avatar
It was working fine for around 3 months....
Old Oct 17, 2005 | 07:28 PM
97PKIMVQ's Avatar
somthing might have come loose. happened to me before with my gauges.
Old Oct 17, 2005 | 09:39 PM
MystA RavE's Avatar
do you think the neon is broken or burnt out for some reason or it has to be with the wiring?
Old Oct 17, 2005 | 10:17 PM
PandaXpress's Avatar
wiring for sure..check behind the shifter trim where the cigarrete lighter is and make sure nothing is lose, and nothing is touching
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
