coil pack screw missing
Old Oct 18, 2005 | 05:02 PM
97SEdriver's Avatar
this place is dead
Hello,
recently I replaced the rear valve cover gasket and in the process lost one of the coil pack screws. Since I couldn't find my spark plug socket at the time and was also a little pressed for time I didn't replace the plugs. I might be imagining it, but I think I'm getting a hesitation around 3500-4000rpm. This could be because I need new plugs, or because I routed the EGR hose back to the TB a little screwed up. But does anyone think it's the coil pack not seated correctly, it seems tight and I was careful aligning it when I tightened the remaining screw.
Anyone run their car with a coil pack screw missing? Was planning on getting another one when I have time, but I was just wondering.
Old Oct 18, 2005 | 06:33 PM
njmodi's Avatar
Do I get a tax break?
I doubt it has anything do do with the missing screw - assuming the one screw is holding the coil pack in place properly.
Old Oct 18, 2005 | 06:39 PM
f550maranello2's Avatar
go to menards and get a new one....
Old Oct 18, 2005 | 07:39 PM
NmexMAX's Avatar
dot dot dot ...
I'm missing 2 or 3 . And it still runs fine .. so that is not your problem...
Old Oct 19, 2005 | 07:08 AM
97SEdriver's Avatar
this place is dead
I figured it wasn't, but thanks for the responses anyway.
What is menards?
Old Oct 19, 2005 | 07:26 AM
I30tMikeD's Avatar
one screw will do the job fine. I only use on screw on all my rears since I pull my plugs alot to check them. The very most rear screw on the back coil packs is annoying and I just don't like messing with it.
Old Oct 19, 2005 | 09:06 AM
97SEdriver's Avatar
this place is dead
You check them often because of the turbo?
Offhand do you know if the EGR hose is sort of crimped going into the TB, would that affect anything?
I have new plugs, and I know they need to be changed, I just don't remember any slight hesitation before I took all this stuff apart.
I really cleaned the TB with TB cleaner from pep boys, but I figure that would improve things.
Old Oct 19, 2005 | 09:39 AM
MDeezy's Avatar
They cost about $.042 each at the dealership.
Old Oct 19, 2005 | 09:40 AM
NmexMAX's Avatar
dot dot dot ...
Less than a nickel ...
Old Oct 19, 2005 | 09:43 AM
MDeezy's Avatar
I got ripped again
Old Oct 19, 2005 | 10:53 AM
Nealoc187's Avatar
SLOW
I have only had 1 screw on each coilpack for the last few years on all of my maximas.
Old Oct 19, 2005 | 10:56 AM
nismology's Avatar
I ran with no screws on the front 3 for a while with no problems.
jmlee44
Oct 2, 2022 02:13 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
