Water leaking from the sunroof control....
Old Oct 20, 2005 | 01:23 PM
GREENlight's Avatar
After about 3-4 straight days of rain, I got a leak from the sunroof control. Has anyone else experienced this or know where the leak may be coming from?
Old Oct 20, 2005 | 01:25 PM
njmodi's Avatar
Do I get a tax break?
Check the sunroof drain hoses for either blockage or disconnections.
Old Oct 20, 2005 | 03:44 PM
nosispower's Avatar
That happened to me once when I left the sunroof open and it got into the sunroof control. Just take the panel off and empty it. Easy peasy.
Old Oct 20, 2005 | 05:34 PM
matts95max's Avatar
yeah it happened to me, my driverside drainhose was disconnected.
Old Oct 20, 2005 | 06:20 PM
matty's Avatar
where are hoses located ??
-matt
Old Oct 21, 2005 | 11:01 PM
aziphrale's Avatar
This is the same issue im having. I went to an auto glass place because it has my car floor soaked. I payed 80 bucks and its the same issue. I read on here somewhere that there is a kit to retrofit the window. ANyone else have any ideas.
Old Oct 22, 2005 | 07:56 AM
DragonMaxima's Avatar
Does anybody have a illustration of the Drain Hose tubes?
I seem to get a small wet spot on where the headliner meets the A pillar when it rains, I believe the Drain hose isn't properly routing the water down into the fender.
Old Oct 22, 2005 | 08:33 AM
Jatan's Avatar
Last post: http://forums.maxima.org/showthread.php?t=434817
Old Oct 22, 2005 | 08:39 AM
Sounbwoy's Avatar
May want to check the seal for the windshield? Mine is messed up at the bottom, so I get a small leak onto my feet in heavy rain....
Old Oct 22, 2005 | 08:54 AM
Thanks for the Picture Jatan.
Is it possible to clog a drain tube and force the water out to the remaining 3 drains?
Old Oct 22, 2005 | 09:11 AM
Jatan's Avatar
Doubt it - if one is clogged then some water might get out from the other tubes but most of it might just "puddle up" and start leaking (this is the case from most people)
Old Oct 22, 2005 | 09:18 AM
96customax's Avatar
my sunroof leaks sometimes.. i think the seal is dry rotted, check your seal
Old Oct 28, 2005 | 12:36 PM
flanboat's Avatar
I'm trying to fix my leak now, I also have water on the drivers side floor and the corner of the A - pillar is wet . I pulled of the molding on the A-pillar but this does not expose any hoses. Do I need to remove the head liner to see the hose to see if it's disconected?
Old Oct 28, 2005 | 12:37 PM
njmodi's Avatar
Ya - pull away some of the headliner near the a-pillar.
Old Oct 29, 2005 | 12:46 PM
crisstyle21's Avatar
wow!!! good post i was wondering why i had some dropps from da control switches...........have 2 look in2 dat
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
