unknown ECU code
Old Oct 20, 2005 | 05:07 PM
lordaphex's Avatar
unknown ECU code
When I check the code for the check engine light with a code scanner it comes up "P0150" What does that mean? I cant find the meaning anywhere. Im probably stupid but I cant figure it out.
Old Oct 20, 2005 | 05:11 PM
7jackmack's Avatar
Front heated oxygen sensor
Old Oct 20, 2005 | 05:15 PM
njmodi's Avatar
Do I get a tax break?
What's so "unknown" about it..
Right from the ECU sticky
P0150 = 0303
0303
Diagnostic Trouble Code 0303 indicates a problem with the front Oxygen Sensor on the left cylinder bank. The left bank is also called the front bank. It is cylinders 2,4,6. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
Old Oct 20, 2005 | 08:13 PM
Ceasars Chariot's Avatar
Old Maxima Legend
haynes manual - P0150 - 0303 : Upstream oxygen sensor or circuit fault (left bank) good luck with it !
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
