speedometer problem
Old Oct 21, 2005 | 10:12 AM
slowalty's Avatar
speedometer problem
I have a 96 maxima and i will be driving down the road and the speedometer quits working. If i press on the face of the gauge cluster it will start wprking. anybody had this problem? what would be loosing in the dash? also i have a check engine light and the code is for the speed sensor.
Old Oct 21, 2005 | 10:13 AM
MaDMvD's Avatar
I have EXACTLY the same problem - literally, exact same problem. Someone please shed some light into this!
Old Oct 21, 2005 | 11:00 AM
LudeAEM's Avatar
haha i have the same problem too. But i dont' have a CEL for it. Just a nice tap on the dash gets it kickin again
Old Oct 21, 2005 | 11:14 AM
Puppet Killer's Avatar
Some body please help! i have the same common problem lol I believe some wire is loose maybe?
Old Oct 21, 2005 | 11:37 AM
hasei's Avatar
日産
Pull out the gauge cluster and re-tighten all the screws in the back of the cluster. Sounds too simple, but sometimes this fix works. I never had the symptom of my speedo not working, but I did have a CEL with multiple codes including a speed sensor code for years, and re-tightening made all the problems go away. It may not fix your problems, but this doesn't cost you anything and it's worth a shot at least before replacing a speedometer or speed sensor.
Old Oct 21, 2005 | 11:51 AM
Maxima lover
Yep, like hasei said take that dash apart and make sure everything is tight. I had a similar problem, my speedometer and odometer stopped working while my tranny was having problems and I went about 8k without it showing on the odometer. I took the dash apart, but couldn't fix the problem. As soon as I had my tranny replaced, it worked fine.
I acually got stopped by an unmarked IL state trooper in a mustang doing 110 and he ask me why I was going that fast. I almost said because my speedometer wasn't working, but I just said, "No reason. I deserve a ticket." He ended up letting me go with a warning.
Old Oct 21, 2005 | 12:13 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Take out the cluster and check all the screws and plugs. If the problem still is not fixed, you may need a new speedo head.
Old Oct 21, 2005 | 12:58 PM
slowalty's Avatar
i might try that this weekend.
Old Oct 21, 2005 | 01:21 PM
Mxrider52's Avatar
I support for what?
Better hope that speed sensor isn't for the one behind the gauge because if it is it gonna cost you about 200-300 to fix it and you will have to replace the whole gauge cluster
Old Oct 21, 2005 | 01:24 PM
MidniteMaxSE's Avatar
this is funny cuz i got the cel today and i went to auto zone ...p0505 speed sensor malfunction....but it works fine...i watched it all day
Old Oct 21, 2005 | 09:39 PM
Supermax95's Avatar
hmmm make sure the plugs that go into the guage cluster are working, it could just be a loose wire....but you guys should look at it the bright way. If the speed sensor isnt giving a signal to your speedometer it sure as hell isnt giving one to your odometer....= D
Old Oct 22, 2005 | 08:05 AM
slowalty's Avatar
It doesnt make me feel good though, i bought my car 3 months ago with 89,000 miles on it. So now im afraid it has more then that. But yea im hopping it just a loose connection.
Old Oct 22, 2005 | 09:42 AM
96customax's Avatar
this will tell you how to take your cluster out.
check your connections and tighten everything
Old Oct 22, 2005 | 10:52 AM
hitman4's Avatar
I have a problem with coilovers where do i go and how do i post??????
Old Oct 22, 2005 | 11:18 AM
tyrotrader's Avatar
No way. Not a sensor. Buy new cluster off ebay and install. That's what I was advised to do and works great now. Others wasted money on buying a speed sensor (I was pulling speed sensor code too)
Old Oct 22, 2005 | 12:37 PM
Vlasic's Avatar
If there is something wrong with his speedometer, why would he buy a whole new cluster when he can just buy the speedo head mechanism in the cluster?
Old Oct 22, 2005 | 01:54 PM
maxter's Avatar
Location of Speed Sensor
Where is the speed sensor located on a 1995 Maxima? I know its on the trans. Where abouts?
Old Oct 23, 2005 | 12:39 AM
Vlasic's Avatar
this is an old pic I have from a while back when I was helping someone install theirs. While standing on the drivers side of the car, lean over the fender and look down at the tranny (you need to take out the intake to do this) and you will see this on the top rear part of the transmission.
Old Oct 23, 2005 | 07:13 AM
LeVeL's Avatar
And I thought I was a n00b...
But yea, my friend's maxima had a speedo problem and tightening the screws worked. good luck
Old Oct 23, 2005 | 09:34 PM
anyone got pics of the speed mechanism located in the cluster?
Old Oct 24, 2005 | 06:57 AM
96mAx2fast's Avatar
Im having a problem w/ my odometer. Im going to take it apart again and make sure everything is tight !!! This sux!!!!
Old Oct 28, 2005 | 09:11 PM
schidam's Avatar
I have some what a similar problem. The Speedometer fails to work in the morning. After car warms up it starts to peg, after a 15 minute drive speedometer works normally. Any suggestions
Old Nov 1, 2005 | 04:36 PM
MaDMvD's Avatar
I removed the cluster and tightened all the screws and it worked perfectly - for a few days.. Yesterday it started up again I guess the cluster must be bad.
Old Nov 2, 2005 | 11:41 AM
seang86's Avatar
i had the speedometer problem before, i took the cluster out and tightened all of the screw on the back and now it works perect. it actually is more accurate now as well. it drops very rarely, but its no biggie. although, if u put a new speedometer in the car, how does the odometer thing work? i never had to fool with that suff, but how willu know what miles u have
Old Nov 2, 2005 | 11:49 AM
Vlasic's Avatar
You would have to go to a dealer and have them reset it for you. Or just open it and change it yourself.
Old Nov 5, 2005 | 04:33 PM
maxter's Avatar
Thanks Vlasic!!! Very helpful.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
