ECU Code 0903
Old Oct 21, 2005 | 06:25 PM
dual's Avatar
ECU Code 0903
Looks like the EVAP canister is going south on the 97 Max. Does anyone have a part number (and approx. cost) along with pictures and/or instructions?
TIA!
Old Oct 22, 2005 | 07:24 AM
InsneDrmr's Avatar
Supposedly 0903 is undefined. But after a few weeks of searching the site, I found that its just a leak in the hose. Which hose? I dont know. Thats just what someone had said. Ive been riding around with this code for months.
Old Oct 22, 2005 | 07:47 PM
dual's Avatar
It's definately defined...
EVAP Canister vent control valve
Old Oct 22, 2005 | 09:40 PM
InsneDrmr's Avatar
haha...look at that...maybe im retarded and put the numbers in backwards...i looked it up months ago. So anyway...how much will this cost.
Old Oct 24, 2005 | 08:11 AM
Curt Deiner's Avatar
I replaced mine several years back. It was like $75 from tustinnissan.com with maxima.org discount. Mine was full of sand and corrosion and wasn't closing properly. Easy replacement. Don't lose the rubber o-ring seal when you remove it.
Old Oct 24, 2005 | 08:20 AM
tomservo291's Avatar
Ok
I've had this code for over a year now, and I STILL don't know exactly what needs to be replaced. I've had people tell me it's the valve that sits behind the throttle body in the engine compartment, and others say its the "black box" behind the rear driver-side wheel.
I would like to take mine apart and try cleaning it first (yes, I know what the stickies say, but many people have said other things too.)
Old Oct 24, 2005 | 08:21 AM
Come to think of it, after all these 0903 threads I've seen/participated in...
I think they were all 97's; interesting...
Old Oct 24, 2005 | 08:54 AM
alpicone's Avatar
my 98 has the 0903 code. I changed the EVAP Canister vent control valve and the code went away. The old valve was rusty. It was about $80 from Courtesy Nissan.
Old Oct 24, 2005 | 09:01 AM
is this the component in the engine bay behind the throttle body or inside the "black box" behind the driverside rear wheel?
Old Oct 24, 2005 | 11:50 AM
alpicone's Avatar
It is on the side of the "black box" behind the rear wheel. It is held on to the box with two screws and has one wire going into it. Very easy to change out. Just make sure to spray the screws with some rust blaster so they dont break.
Old Oct 24, 2005 | 03:41 PM
dual's Avatar
Do you remember what the part number is?
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
