Air coming out vents all the time?
Old Oct 22, 2005 | 08:15 AM
Mxrider52's Avatar
I support for what?
Why is there air coming out of the vents in my car all the time? I got the control off but there always air coming out. I have a manual climate control system
Old Oct 22, 2005 | 08:21 AM
Kismet's Avatar
I have a 99 maxima and it will do the same thing if the Recirculate button is off with the A/C set to blow air through the top vents only.
HTH
Kismet
Old Oct 22, 2005 | 08:29 AM
InsneDrmr's Avatar
If its set to fresh, air will always blow in.
Old Oct 22, 2005 | 08:31 AM
Sounbwoy's Avatar
What? Unless you have RECIRC ON, you'll always get air thru your top vents as you drive....Get/read the manual, man
Old Oct 22, 2005 | 09:24 AM
96customax's Avatar
yeah a little bit of air always comes thru.. dont feel bad my air will only work on 4
Old Oct 22, 2005 | 09:32 AM
Jatan's Avatar
Same thing here but I only feel it on the highway
http://forums.maxima.org/showpost.ph...2&postcount=31
Old Oct 22, 2005 | 09:35 AM
96customax's Avatar
i was told it was the resistor for the switch or something like that
Old Oct 22, 2005 | 11:08 AM
njmaxseltd's Avatar
It's supposed to blow fresh air all the time. How do you think they keep the car's exhaust gases out of the cabin? The HVAC systems should always bring fresh air into your car. There are direction control air vent valves in your quarter pannels to control air flow through the vehicle. Keeps you from getting killed by your exhaust. Keeping the system off by using the REC mode will also make your windows fog up when their closed.
Old Oct 22, 2005 | 11:45 AM
hitman4's Avatar
it is designed to blow through a little...but when your at high speeds, you will feel it more. Internal modifications??...................possible. Just take apart half of your front end...not much
Old Oct 22, 2005 | 12:55 PM
kcryan's Avatar
its designed to do this
Old Oct 22, 2005 | 12:59 PM
Rotncarcas's Avatar
Think about it... when your traveling at faster speeds, more air is moving by the car. The intake for the climate control system is getting blasted with more air, so naturally more air is going to flow through....
(I'm going to feel really dumb if this is a wrong hypothesis)
Old Oct 22, 2005 | 01:05 PM
Mxrider52's Avatar
I support for what?
Was curious because some cars dont do this
Old Oct 23, 2005 | 10:05 PM
jdrvr18's Avatar
Yea mine does too, but my air used to only work on fan speed 4 until i replaced the resistor. It costed me bout 40 bucks from a nissan part site and took like 5min to put in. Very simple. Theres a post somewhere about it.
Old Oct 24, 2005 | 09:39 AM
MaximaSE96's Avatar
Maxima Owner
mine blows through the floor vents at high speeds.....the cool thing is at high speeds the fan slows down cause it has so much air moving throug it.....but the little fan thingy still has 4 blades lit up....are they like dual stage blower fans or something
Old Oct 24, 2005 | 01:40 PM
CreativeDesignz's Avatar
just ptu the on recirculate and it wont blow through i didnt think that this could really get as in depth as it has.
Hondarydr
Dec 30, 2024 06:15 PM
vingodine
45
May 21, 2016 12:46 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
