valve body question
Old Oct 22, 2005 | 05:28 PM
tuko's Avatar
valve body question
can any transmission shop do a valve body mod or are there only certain shops that do this?
Old Oct 22, 2005 | 05:34 PM
njmaxseltd's Avatar
Just about any tranny mechanic familar with high performance should be able to mod a Maxima VB. All thats done is a pressure increase by drilling out a few bores. If you know the VB, it's easy to see 1st and 2nd gear fluid bores which are usually the ones that are changed.
Old Oct 22, 2005 | 05:43 PM
tuko's Avatar
do you know how much $$$ I'd be spending on this mod?
Old Oct 22, 2005 | 05:46 PM
Dubbya's Avatar
VK56 Inside
Maximum Tuning charges $400 to do the modification.
Old Oct 22, 2005 | 06:06 PM
2 Da Max's Avatar
so is it possible any could do this??
Old Oct 22, 2005 | 06:11 PM
Dubbya's Avatar
VK56 Inside
Its possible, but not probable. I would think the risk of ruining your VB is great for someone that hasnt done this type of work before.
Old Oct 22, 2005 | 07:08 PM
2 Da Max's Avatar
Valve Body Mod
Description: For automatic transmissions only. Makes the transmission shift quicker between gears. And even though the shifts feel harsher it actually prolongs the life of your tranny. Known to decrease 1/4 mile times by .1. It is also recommended that you get a tranny cooler if you do this mod since it causes your tranny to run hotter.
i got this from the maxmod website, Decrease by .1? for 400? ... dam so i fi run 15.3, ill run 15.2... i guess getting an upgraded ecu is smarter than
mvm062
Nov 30, 2020 09:00 AM
tgreen
Oct 18, 2015 06:18 PM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
Johnny9595
Sep 3, 2015 05:18 AM
