Junkyard Treasure
Old Oct 22, 2005 | 05:53 PM
Dubbya's Avatar
VK56 Inside
Junkyard Treasure
Went to a yard way out in BFE Texas (about a hour north of Austin) and found these beauties just sitting there for the picking. Obviously these guys didnt give a crap about the imports in the yard because I got these for a retarded price. Sorry for the crap image quality.
And Ralf......I am keeping them.
Old Oct 22, 2005 | 05:56 PM
2 Da Max's Avatar
good find.. you couldn find any other things like lines or brackets?
Old Oct 22, 2005 | 06:03 PM
sunten1
I take it those are brakes off a 300zx?
Old Oct 22, 2005 | 06:05 PM
Dubbya's Avatar
VK56 Inside
Im going to put ss lines on there so I junked the old ones. What brackets? I didnt know I needed brackets off the 300z. The calipers were held on to the hub by 2 19mm bolts and a bracket for the hard line coming out of the caliper.
I think I am going back out there on the next pay day to snag the rears.
Old Oct 22, 2005 | 06:09 PM
Dubbya's Avatar
VK56 Inside
Correct, sir.
Old Oct 22, 2005 | 08:54 PM
cnenov's Avatar
I have a 300ZX for sale right now, but in the last two years that I have owned it I have never even seen a 300ZX in a junk yard. Good find - over $100 on eBay. I have a different problem though on the Max. I have enough stopping power (no ABS) and I try to pump the brakes and still slide all over the place when I try to stop in a hurry(running stock rims with I dont know what tires - got the car about a month ago). Will this change with aftermarket wheels/tires (being wider)?
Old Oct 23, 2005 | 05:16 AM
Capital15's Avatar
Nice find. Post pics when you install them!
Old Oct 23, 2005 | 06:05 AM
SkinnyMax's Avatar
maxima no more
If you use the rears you won't have a parking brake unless you use Matt Blehm's rear big brake kit, the 300zx uses a seperate drum brake as the parking brake.
Put on some decent rubber (doesn't have to be wider) and that problem will go away, you can only stop as fast as your tires will allow.
Old Oct 23, 2005 | 02:57 PM
Flava_24/7's Avatar
Boosted Panda
The lines and brackets are useless for the maxima conversion.
Old Oct 23, 2005 | 02:58 PM
Flava_24/7's Avatar
Boosted Panda
Sweet!
So what are you going to do about the wheel issue?
Old Oct 23, 2005 | 03:53 PM
PandaXpress's Avatar
nice...let us know what else you pick up at the junkyard tommorow
Old Oct 23, 2005 | 04:08 PM
Nealoc187's Avatar
SLOW
Are those 26mm or 30mm calipers?
Old Oct 23, 2005 | 04:35 PM
Flava_24/7's Avatar
Boosted Panda
They came off a 90 non turbo 300z so Im going to say that they are the 26mm Aluminum calipers.
Old Oct 23, 2005 | 07:32 PM
nosispower's Avatar
Wider tires make it easier to hydroplane
Old Oct 24, 2005 | 07:42 AM
Dubbya's Avatar
VK56 Inside
Originally Posted by FLAVOR_24/7
Sweet!
spacers
Old Oct 24, 2005 | 07:44 AM
Dubbya's Avatar
VK56 Inside
So there is some sort of bracket he makes to use the cable driven e-brake?
Old Oct 24, 2005 | 09:39 AM
MDeezy's Avatar
you have all 4 claipers dubbya?
I thought when people used the 300zx they just did the fronts and left the rear stock
Old Oct 24, 2005 | 10:55 AM
Dubbya's Avatar
VK56 Inside
I have the fronts for now. The rears are there for the taking when I get a chance to go back out there. They are gonna be a bish to get though. The car is on the ground with on tire on the rear so I will have to jack it up to pull the parts. Its a self service yard. Matt makes a kit for the rears. I want them all. I think it will look pretty hot with all 4 on there.
Old Oct 24, 2005 | 11:22 AM
SkinnyMax's Avatar
maxima no more
Matts kit is pretty involved and is also not real cheap, but if you have the funds/time then go for, I'm all for having a good set of brakes. http://www.mattblehm.com/rear_kit.htm
Old Oct 24, 2005 | 11:30 AM
Dubbya's Avatar
VK56 Inside
That is quite costly. But what the heck. Im going to do it eventually.
Old Oct 24, 2005 | 12:42 PM
Jepht20's Avatar
Custom User Title...
how much do these usually go for? i saw some at a junkyard that i'm going back to this week and will ask them how much...i have no plans on using them, but would either resell on the org or pass the deal to another member.
Old Oct 24, 2005 | 01:03 PM
Dubbya's Avatar
VK56 Inside
The go from anywhere around $150 and up. Although I got mine for $42.50 out the door.
Old Oct 24, 2005 | 01:08 PM
DR-Max's Avatar
Hopefully those calipers are still in good working condition.
Old Oct 24, 2005 | 01:15 PM
Dubbya's Avatar
VK56 Inside
I think they are. All of the pistons moved freely back into the bore. If they end up being POSes then I will take them to autozone and get remaned ones or just buy the rebuild kits. I will still come out with a good price.
gavin68
Sep 18, 2021 12:36 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxima297
Sep 24, 2015 08:57 PM
followthadollar
Sep 17, 2015 06:31 PM
Violator
Sep 9, 2015 10:14 AM
