look at my E46 projectors/bezels (pics)...I have a few questions...
Old Oct 23, 2005 | 11:28 AM
kingrukus's Avatar
no more maxima...
The bezel seems to be part of the rest of headlight chrome/housing...how did you guys seperate this? I thought it was supposed to be seperate?
Also I noticed that I ended up with 2 right side projectors/bezels...any problem with this, or should I demand that I get a left and right side from the seller?
Additionally what type of drive did you use to remove the projector from the bezel/housing?
Also for you E46 single xenon retrofit guys, did you use the OEM bezel or a differnet bezel?
Old Oct 23, 2005 | 11:36 AM
Nismo3112's Avatar
Custom User Title
The projectors should come off the bezel if you remove the 4 screws. I'm not sure what type of driver that is but they should sell it at Sears.
This is what I used for my bezel:
Old Oct 23, 2005 | 11:59 AM
maximus_96's Avatar
use a torx bit to take the projectors out. the bezel is clipped onto the projector by two clips. if you try to pop the bezel out w/o taking the projectors off first, you might snap a clip, they're fragile.
Old Oct 23, 2005 | 12:15 PM
Nismo3112's Avatar
Custom User Title
Oh yeah it should be fine that you have 2 of the same sides. The projectors should be the same.
Old Oct 23, 2005 | 12:28 PM
kingrukus's Avatar
no more maxima...
This is a genius idea...I think I will use something similar because it will be far easier to cut and such. What is the point behind a bezel anyways? Just to hide the mechanicals of the projector? If there is no point I may just end up painting them a flat silver.
Old Oct 23, 2005 | 12:30 PM
wannaboostbad's Avatar
those projectors have tamper proof torx on them, dont forget that and get the regular torx cuz they wont fit.
Old Oct 23, 2005 | 12:51 PM
Nismo3112's Avatar
Custom User Title
Basically, it's just there so it looks nice. Mine is sort of a bezel/shroud because it also blocks out the light spilled out from the sides.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
