atermarket hood struts / supports
Old Oct 23, 2005 | 01:08 PM
GoldMax99's Avatar
I bought some supports from Advance auto parts and they require taking out the old ball bearing bolts from the old supports. How do you do this? They seem to be permanently attached to the support.
Thanks in advance.
Old Oct 23, 2005 | 01:19 PM
DrTySOUFMaX23's Avatar
need a pair pliers or vice grip and pry it out..
Old Oct 23, 2005 | 01:33 PM
GoldMax99's Avatar
I tried pliers and couldn't do it. I'll try the vice grip.
Old Oct 23, 2005 | 01:37 PM
ewuzh's Avatar
Return em and go with autozone struts. It's a direct factory replacement. Screw out the old and screw in the new. No need to pull out the support from the ball joint screw.
Old Oct 23, 2005 | 01:38 PM
GoldMax99's Avatar
Awesome advice. Thanks. Rep pts for u.
Old Oct 23, 2005 | 01:39 PM
JwaxMax99's Avatar
Noooo, the little black clips pull back and they fall right out. Use a small screwdriver.
Old Oct 23, 2005 | 02:35 PM
GoldMax99's Avatar
There are no clips on the factory ones. Only the aftermarket (Advance) have the clips. But my problem is getting them out of the factory ones.
Old Oct 23, 2005 | 06:48 PM
Mxrider52's Avatar
I support for what?
I just installed the ones from advance last night all you gotta do is unscrew the ball joint top and bottom and the whole strut comes off then screw the other ball joints in and pop the strut in
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
leatherneck
Sep 30, 2015 09:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
