valve body question
READ THE STICKIES. Its a modification of your trasnmission, Its not something you buy and install. Theres a place in NY that does it that has a website but I just cant think of the name right now.
https://maxima.org/faq-4-Performance.html#33
Your going to have to find someone else to do it. I'm not sure but I would think just about any transmission shop could do it but I would just call around to some places. I've heard prices around $300-$400.
300-400$
Shouldn't be more than 90$, or an hour or 2 of your time at home .. get a haynes or read the stickys(5th gen stickys have a good write-up) Same as changing fluid out with a few more bolts ...
300-400$
300-400$
300-400$
I think he was quoting the price to actually mod the valve body. If so then hes right on.
Originally Posted by drew76924
but y would they have a modification in the haynes manual..
You send it to maximum tuning .. they modify it .. you put the modified one in, same as a 'replacement' hence its place in the haynes manual.
.... He should be more clear though .. but you're correct, and I may have jumped the gun as always.
Ok here is the deal.
Maximum Tuning sells them already modified for $600. There is a $200 core charge in that price. So that being said the final price would be $400 after you return a stock valve body to them. Then you need to get it installed. Prices vary from $50 - $100. Good luck hunting.
Not worth the price ... DR mod is better if you can do a WOT switch
I have a stage II.5 on my 03 and DR mod on my 95 .. 95 doesn't have enough power to justify it(VB mod $).
Extended rev limtier helps more(w/VI of course) since you can shift later in the rev range and be ain a beefier spot when entering next gear... if stock limiter is used, you end up in a dead spot in the 1-2 shift w/ DR/VB .. do NOT ask about the DR mod... better yet check the stickys.
wait.... im confused the 90 dollars you stated above, were u talking about installation price? or to actually bore out the vb?
i want to get this done but 400dollars for .1 second gain? is it really worth it in your opinion?
Originally Posted by 2 Da Max
no what i am saying nmexmax and dubbya, do you guys think its worth it for a .1 difference on the track?
I didnt buy it for the track. I bought it because I have a Vq35 and want to do everything possible to extend the life of my transmission. If I was at the track I would say that it would be worth it. .1 of a second is a alright gain for one modification plus it extends the life of the transmission that you are beating on. But then again, I dont like to comprimise on what I put into my car. Id rather spend a little more money to have quality stuff.
03VQMAX
Sep 5, 2015 03:47 PM
