For those who are lowered with kyb AGXs
Old Oct 24, 2005 | 08:19 AM
Gramdacious's Avatar
What settings did you put the front and the rears on? I am running intrax with almost a 2" drop and I live in California with horrible roads so I want some comfort. I just bought the AGXs and have no clue. Thanks for any info.
Old Oct 24, 2005 | 08:46 AM
old_G22's Avatar
im on 2 front and 6 back, nice ride for me.
Old Oct 24, 2005 | 08:59 AM
krzymax's Avatar
Maxima owner since 2000
2 front/4 back
Old Oct 24, 2005 | 09:04 AM
96blackmaxSE's Avatar
boost me.....
Originally Posted by KrZyMaX
2 front/4 back
same...................
Old Oct 24, 2005 | 09:36 AM
MaximaSE96's Avatar
Maxima Owner
track use 3 front 8 rear(lack of RSB prompts me to make stiffer than front)....crusing 1 front and 3 rear
MDeezy's Avatar
If you want the softest ride go 1 , 1.
Old Oct 24, 2005 | 01:25 PM
njmaxseltd's Avatar
The words, "lowered, comfort & AGX's" should never be used in the same sentence.
It's impossible to achieve comfort under those cercumstances.
Old Oct 24, 2005 | 01:29 PM
tavarish's Avatar
fwd gone rwd cr00
i have the fronts set to 2, backs set to (i have no idea), never set them.
Old Oct 24, 2005 | 01:55 PM
Your right, I should just cut the springs and give up.
Old Oct 24, 2005 | 03:46 PM
ewuzh's Avatar
3F/7R - good.
I tried 4F/8R, it rides like a skateboard.
Old Oct 24, 2005 | 10:19 PM
It seems like 2 in the front is a popular route. Thanks for all the info. Northern California are f*#%ing terrible and anything's better than what I've got now.
Old Oct 26, 2005 | 02:15 PM
RA030726's Avatar
I'm nutty for Nissans
ive been on 1 for months now. anything else is way too stiff.
Old Oct 26, 2005 | 03:32 PM
Really? OK that's good to know cause out here the roads are freakin terrible. So #1 is still a "sport" type setting? In other words; is the car floaty? or too soft around corners? Thanks for the response.
Old Oct 26, 2005 | 06:50 PM
z32drifter's Avatar
I'm on 3f 6r for the street and used 4f 8r for the track. I would suggest that you try a setting for a few days then change it and see what you think. I've used about all the settings on the struts and found 3/6 best for how and where I drive. I found that the lower settings felt like they lacked enough rebound for the S-techs.
Old Oct 26, 2005 | 10:19 PM
Supermax95's Avatar
1 and 1...i had them on 4 and 8 before, man that thing was stiff, but handled like a dream.
Old Oct 27, 2005 | 12:29 PM
greengrass215's Avatar
front set to 4 and rear set to 4, perfect for city driving for me
Old Oct 27, 2005 | 12:42 PM
Nissan 6's Avatar
OT does anyone recommend these shocks because Im seriously considering them...
Old Oct 27, 2005 | 01:53 PM
RA030726's Avatar
when i first tried 1 with the Canuck springs the front was bouncy (not enough rebound) so i had to run them on 2 up front. then after a few weeks or a month i messed around and ended up back to 1. the ride is good. i mean its as comfortable as possible on these struts. which in reality suck for street use because they are stiff anyhow. when you go to get a better ride you cant. the higher you go the compression and rebound both increase. the ride suffers and the wheels lose contact with the road since the rebound is to slow (a stiffer spring would need the extra dampening and rebound). basicly they are way over board for a street set up with mild progressive rate springs. i would buy illuminas if you drive on the street and occationally race.
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
