Question about ECU Codes...Oh God
Old Oct 26, 2005 | 03:25 PM
Saddles's Avatar
Okay so I have the codes 3-7, 7-6, and I swear I watched it blink 15-7 but this apparently isnt a valid code? 3-7 came back as a Closed Loop Control, what exactly is that and what needs to be done to correct this? 7-6 shows undefined. Anyone know what they are? I recently had some exhaust work done in which one of my o2 sensors needs to be replaced because the threads are jacked up due to someone selling me a bum y-pipe off of the .org. The codes didnt throw the cel until a couple days after the exhaust work so I'm assuming as soon as I can replace that o2 sensor and have a new bung welded in the pipe it will probably go away. But just want to make sure my car isn't in any real danger. Thanks
Old Oct 26, 2005 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
For the codes you were not able to get, (undefined) try it again and count carefully. Get a haynes
0307
Diagnostic Trouble Code 0307 points to a problem with the Engine Control Module Closed Loop Logic for the Left Bank. The left cylinder bank is also called the front bank. It is cylinders 2,4,6.
DTC 0307 is detected when the closed loop control function for the left bank does not operate even when the vehicle conditions meet the criteria (engine at normal operating temperature, etc.). Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor sensing element.
- a defective Front Heated Oxygen Sensor heater.
Old Oct 26, 2005 | 05:48 PM
Saddles's Avatar
i guess that solves that then for the most part, cel got tripped because my o2 sensor flappin like a flag in my engine bay. No idea how long the other codes have been there. I counted them probably 3 times each. I guess Ill just have to wait until the cel trips again and then reread them. Thank you sir, very good answer very quickly!
Old Oct 26, 2005 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
Did you not read all of my psot where I stated
Originally Posted by NmexMAX
Get a haynes
0706 Fuel injection system lean or rich (right bank)
I've never heard of codes blinking so many x's, so I'm going to guess and say try it again .. but you probably cannot since you reset the ECU
Old Oct 26, 2005 | 06:06 PM
njmodi's Avatar
Do I get a tax break?
Both of your front O2 sensors are shot... they might have been damaged during your y-pipe install.
Old Oct 27, 2005 | 10:45 AM
Saddles's Avatar
I read your post, not sure why that needs quoting. The o2s are cheap splices that I didn't install...most likely will get a couple of oem replacements and put them in. Thanks. And yeah like I said, ill try and read them again when the cel trips again.
Old Oct 27, 2005 | 12:03 PM
njmodi's Avatar
Get the Bosch OEM connector O2 sensors from www.oxygensensors.com, 70 bucks and plug and play and as good as original Nissan (since bosch is the OEM for Nissan o2 sensors).
Old Oct 28, 2005 | 10:09 AM
Saddles's Avatar
Thanks njmodi, ill prolly do that..soon...cars going in the shop to get paint wednesday so i hope my exhaust gets fixed early in the week or late
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
