fan is on all the time???
Old Oct 26, 2005 | 06:36 PM
st8rider's Avatar
I just changed the coolent and thermistat in my 98 max and now the fan seems to stay on all the time...the thermistat reads in the middle and dont over heat.
any feed back wood be help full
Old Oct 26, 2005 | 06:39 PM
njmodi's Avatar
Do I get a tax break?
The fan will be on if your A/C is on...
Old Oct 26, 2005 | 07:23 PM
kcryan's Avatar
the man makes a very good point
Old Oct 26, 2005 | 07:39 PM
Sounbwoy's Avatar
Did you bleed all the air out of the cooling system? I don't know how accurate the temp gauge is in our cars. Even on the hottest day, my gauge goes to the middle and doesn't move once it gets there....By the same token, my fans didn't seem to act any differently when I changed my t'stat, but the heat does take a little longer to come on when it's cold, even after I got the air out of the system...
Old Oct 26, 2005 | 08:07 PM
Jime's Avatar
It will also be on if your defrost is on.
Old Oct 26, 2005 | 09:16 PM
njmodi's Avatar
Yes - because defrost turns on the A/C
Old Oct 27, 2005 | 12:35 AM
Jime's Avatar
Not in the winter, its heat but it still turns the fans on.
Old Oct 27, 2005 | 04:26 AM
njmaxseltd's Avatar
If you use auto climate control, the compressor runs all the time if it's above freezing.
Compressor on = fans on.
Old Oct 27, 2005 | 10:45 AM
st8rider's Avatar
I have every thing off ( a/c, defrost) How do you know if you didn"t get all the air out? All i did was drain the coolant from the bottem and put new coolant in. i poured in the coolant in slowly so i wouldnt get any air.
Old Oct 27, 2005 | 12:40 PM
kcryan's Avatar
wait till its cool, take off the the Rad cap, start the engine, and sit there for 5 minutes making sure that when bubbles come to the top you add more coolant/water. thats what i do.then shut it off and put the cap back on
Old Oct 27, 2005 | 02:25 PM
RA030726's Avatar
I'm nutty for Nissans
there are 2 temp sensors, one for the gauge and one to the ecu which controls the fans. if indeed the car is running fine, and the temp gauge works, then the temp sensor for the ecu could be broken.
Old Oct 27, 2005 | 03:31 PM
michaelnyden's Avatar
you mean your fan is on even when your car is turned off?
is so then look at your relays under the hood...the one for the fan is brown if memory serves...and if it's really really hot to the touch then it's bad...take it out and smell if it's burnt up...
but if you mean the fan only stays on when the car is on...then take the suggestions from those above...
Old Oct 30, 2005 | 02:23 PM
st8rider's Avatar
no the fan is on when the the car is on. (sorry it took so long to reply whent to Disneyland for 2 days)
Old Oct 30, 2005 | 03:14 PM
prolly the coolant temp sensor....very easy to test if you have a multimeter...very easy to change as well...look in the FSM or chiltons/haynes
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
Carlos Levy
Aug 23, 2015 08:48 PM
doobadoo
Aug 15, 2015 06:43 PM
