Picture Or Better Description of O2 Sensor Connector Locations
Oct 28, 2005 | 10:11 PM
Besides the description in the sticky for changing the front O2 sensors,
does anyone have any pictures of the connector locations, or a more detailed word description, including how many other clips there are holding
the wires from the sensor all the way to the connector.
Oct 29, 2005 | 05:27 AM
The connectors are right in front of the engine by the cooling fans. Follow the wire and remove it clip by clip. There are about 6 or 8 clips holding the wire in place. A OEM replacement unit has new clips in the correct locations already installed on the wire. It doesn't get any easier then that.
Oct 29, 2005 | 10:47 AM
I replaced both of my O2 sensors when I installed my new Y Pipe. It's very easy if you start at the O2 sensor, and just follow the wire up to the connector. The previous post pretty much hit the nail right on the head. Grap a flat head screwdriver in case the clips don't want to pop out. Wedge the screw driver behind the clip and give it a tap. Other than that, it's pretty cut and dry.
Oct 30, 2005 | 03:18 PM
Here you go...
