02 sensor?
Old Oct 26, 2005 | 07:05 PM
S103100F's Avatar
02 sensor?
what are the chances on a bad 02 sensor no cel?
if is bad or runing rich/lean does it always trigers cel?
Old Oct 26, 2005 | 07:09 PM
njmodi's Avatar
Do I get a tax break?
A lazy O2 sensor may not trigger the CEL, but you have more problems than just a lazy O2 sensor if you are getting 10mpg (from your other thread).
Old Oct 26, 2005 | 07:11 PM
S103100F's Avatar
i dont know what to start from ? this $3.00+ a gal is killing me big time
Old Oct 26, 2005 | 07:22 PM
njmodi's Avatar
It's a little difficult to track what has been suggested and tried so far since you started a new thread... but are there any codes stored in the ECU? Did you go to Autozone and have them retrieve the codes?
Old Oct 26, 2005 | 07:30 PM
S103100F's Avatar
no codes i had a problem with egr but i got that fixed my mechanic told me i am using so much gas bc my egr wasnt working now i got that fixed still same problem time that i had problem with egr after reseting ecu cel would come up after like 10 min of driving now i am driving for like a week no cel
Old Oct 26, 2005 | 07:38 PM
PLUMMAXSE's Avatar
Try to test your mileage in the city vs the hwy. Your hwy mileage if you are cruising around 60-65 should be almost 30mpg. If that is the case, but your city mileage is low(10-18) then you might have lazy o2 sensors. The sensors aren't sending the right info to the ecu until they have been running a while. Thus bad MPG. I changed mine for that reason and restored my overall mileage to 25 including city driving. JMHO
Old Oct 26, 2005 | 07:46 PM
S103100F's Avatar
is there a way to test them ?
Old Oct 27, 2005 | 01:50 AM
Ceasars Chariot's Avatar
Old Maxima Legend
well i had 05 03 right bank o2 sensor for almost a year, and then when I got around to replacing it i rechecked the codes and it was gone ? i replaced it anyway but had no explanation as to why the codes no longer showed.
Old Oct 27, 2005 | 05:15 AM
S103100F's Avatar
i see but is there like a way to check them some how
Old Oct 27, 2005 | 05:34 AM
PLUMMAXSE's Avatar
If you have 100k miles on your sensors, it probably time to change them!!
Old Oct 27, 2005 | 05:43 AM
S103100F's Avatar
i had front right one and back sensor changed only left one is old well i dont know how old i only have this car for like 2 1/2 years so i dont know
Old Oct 27, 2005 | 05:45 AM
PLUMMAXSE's Avatar
How many miles on your 96?
Old Oct 27, 2005 | 05:48 AM
PLUMMAXSE's Avatar
The rear o2 sensor doesn't affect your mileage. The 2 front sensors will give you bad mileage if old. I would just change the other front o2 sensor and start fresh!! Gas is expensive.
S103100F's Avatar
about 122k
Old Oct 27, 2005 | 05:51 AM
S103100F's Avatar
thanx i'll do that
o and one more thing is there a big diff oem or aftermarket 02
Old Oct 27, 2005 | 07:28 AM
njmodi's Avatar
Originally Posted by S103100F
thanx i'll do that
get a Bosch OEM equivalent from www.oxygensensors.com - $70
Old Oct 27, 2005 | 12:39 PM
S103100F's Avatar
thats each right
how about from dealership how much they go for?
Old Oct 27, 2005 | 12:40 PM
njmodi's Avatar
thats each right
yes, 70 bucks each, as opposed to 120-180 depending on which dealer you go to (online, local, etc.).
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
