Diamond Corners, fitment?
Old Oct 29, 2005 | 01:40 PM
XaMMax's Avatar
I am about to buy the diamond cut corners for my 96 max to match the 97 headlights (on their way). My question is that custom enterprise says that i will need to reuse my factory bulb wiring harness. What does this mean exactly?
http://www.customenterprise.com/view...sd/scspid/4717
Old Oct 29, 2005 | 05:06 PM
Kta920's Avatar
pop out stock side marker with flat head screw driver and cloth,twist socket til it comes off.un-screw phillips head front bumper light,do same.and reverse for install.dont worry about it.takes literally 2 minutes,and there is barely any thinking involved.
Old Oct 29, 2005 | 05:32 PM
XaMMax's Avatar
Yeh I've pulled out my corners before I just wasn't sure how complicated these would be after what it said about reusing wireness harnesses..
Old Oct 29, 2005 | 05:39 PM
Kta920's Avatar
just means all you're buying is lenses and possibly bulbs.aka,dont cut anything.it'll be obvious when you go to install 'em.
Old Oct 30, 2005 | 06:50 PM
Stuntin' 101's Avatar
your just replacing the light housing itself.. and using the original socket and wiring that the bulb connect to. check out ebay, or procarparts.com for those lights.. i just bought the corners and matching headlights from them.. the only fittment issue i had, is i did not get the little ball socket joint to snap in.. they might go in fine if i play with them, i just havent gotten around to doing it.. too many other things on my plate
Old Oct 30, 2005 | 09:00 PM
maxspeed96's Avatar
When I baught mine, they came with wire harnesses, but theyre for 97-99 models. 95-96 are different. The clip is different. I think what theyre trying tp say is that you need to use yours that are already on the car and not the ones that come with the lights.
Old Nov 11, 2005 | 06:14 PM
XaMMax's Avatar
Yeh, I just got them in the mail and it seems that way..
Old Nov 12, 2005 | 05:38 AM
Louie Max's Avatar
when you install the corners put double sided tape for security...
as easy as they are to install... they're as easy to steal... i've had them stolen twice... damn nyc
aw11power
Oct 10, 2021 04:57 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
JoshG
21
Sep 4, 2015 09:04 PM
griffins98max
Aug 30, 2015 10:23 PM
