Eibach springs.
Old Nov 3, 2005 | 12:55 PM
kajeno's Avatar
Eibach springs.
When installing, do the letters on the springs suppose to point upward? (I got the answer)
Please answer the question below:
Also will I need to compress them (front and/or back) for the install? The reason I am asking is b/c when I did my friend H&R we did not. Thanks.
Old Nov 3, 2005 | 01:44 PM
SPiG's Avatar
SomePsychoGuy
Rent a spring compressor from autozone.
Old Nov 3, 2005 | 01:48 PM
Groundz's Avatar
Spring compressor? whats that for???
J/K
Old Nov 3, 2005 | 01:54 PM
RA030726's Avatar
I'm nutty for Nissans
It depends on if you want to mucle them. I just muscle the rears, its easy. sometimes the fronts need the compressors. Its been so long since I installed the Eibachs, but when they were new I used the compressor.
Old Nov 3, 2005 | 04:58 PM
rocco5446's Avatar
If you're switching from stock springs, you'll have to compress those for sure before removing them. As to the Eibach's, you won't need to compress them, just press down on the strut mount with a bit of your body weight before attaching the top bolt.
Old Nov 3, 2005 | 06:20 PM
the_3d_man's Avatar
I had to compress the Eibachs a little... they are very stiff so it's hard to squeeze them even an inch or two. but then again I'm not that strong... so whatever
i don't see why you shouldn't use a compressor
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
morteljc
Oct 19, 2015 10:47 AM
95Maxi
35
Sep 2, 2015 10:37 AM
official_style
Aug 29, 2015 10:10 AM
