Problem with blinkers
Old Nov 4, 2005 | 09:38 AM
SchismistiC's Avatar
Sup people I have a question. This just happend recently. My turn signals dont go on but when i turn on my hazards the signal lights up. Where exactly can i find the problem to this signal error? I think some connection isnt touching right or something but this just happend like two days ago please let me know what you all think it might be. Thanks!
Old Nov 4, 2005 | 10:27 AM
njmodi's Avatar
Do I get a tax break?
Sounds like a problem with the turn signal/headlight stalk in the steering column.
Old Nov 4, 2005 | 10:31 AM
chak210's Avatar
Check your bulbs and fuses
Old Nov 4, 2005 | 10:38 AM
pmohr's Avatar
No more Maximas...
BTW you know your car description reads '95 Pearl White 95 Maxima SE SE'? Just a bit redundant.
Old Nov 4, 2005 | 10:39 AM
njmodi's Avatar
Did you read his post? He said the signals work when the hazard button is used, but not when the stalk is used.
Old Nov 4, 2005 | 11:04 AM
MrEous's Avatar
^ Jeff™
If I had a blinker bulb out on my car the hazard lights in the gauges worked normal.
Old Nov 4, 2005 | 11:17 AM
THT's Avatar
THT
Throbbing member
Blinker fluid low?
But really, check the wand/stalk for any connection problems.
Old Nov 4, 2005 | 11:27 AM
I kinda figured it be in the column but i dont see why it would mess up all of a sudden. maybe it said "IM GUNNA BE GHEY TODAY!" I was gunna check that out today but i looked at the column and i just got the biggest case of laziness right when i saw that. Don't worry ill figure it out and open it up Its just wierd that the hazards work and turn the lights on the front and back. but when i use the turn signals the back or front ones dont light up... wierd huh
Yeah i noticed that but i just been too lazy to change it school and work doesnt mix well Just for that ill change it just for you
Old Nov 4, 2005 | 11:48 AM
njmodi's Avatar
I believe the bulbs themselves worked fine with the hazards on (at least that was my interpretation), not the dashboard indicators
Old Nov 5, 2005 | 11:04 PM
Louie Max's Avatar
Most likely its the directional flasher
Old Nov 6, 2005 | 12:00 AM
Thanks guys i got them fixed yesterday as well as my side lamps. they were just blown fuses :S a bunch of trail and error. Especially mounting new aftermarket headlights on a salvaged maxima that got hit in the front end... ****ed up fitment but some smacking around did the trick.
Old Nov 6, 2005 | 12:42 AM
MaximaSpd85's Avatar
fuses huh? i think chak210 deserves an apology, lol!
Old Nov 6, 2005 | 05:25 AM
njmodi's Avatar
chak210 - apologies for my previous statement..
Old Nov 6, 2005 | 07:00 AM
njmaxseltd's Avatar
Replace the flasher relay, it's under the dash, driver side. It's the device you hear when your directionals or flashers are on.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
