does changing the clutch require draining the trans fluid?
Old Nov 4, 2005 | 11:31 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
Wondering if i need to buy more AMS/redline synthetic for an upcoming clutch swap.
Old Nov 4, 2005 | 11:46 AM
mtrai760's Avatar
'Trynna' is not a word
Yes. 10 char
Old Nov 4, 2005 | 11:49 AM
nismology's Avatar
You don't necesarily need to drain all of it. The only reason you need to drain some is so it doesn't leak out of the differential hole when you remove the axles. But you might as well drain it all out, especially if a fluid change is due.
Old Nov 4, 2005 | 12:26 PM
Dan's Avatar
Dan
Can it be recovered, or do i need to buy more fluid? If so how much?
Old Nov 4, 2005 | 12:28 PM
mtrai760's Avatar
If you drain it into a clean container you can keep contamination out of. Then you just have to worry about getting it into a bottle, then into the tranny. Don't be lazy, look up the capacity you can use the search.
Old Nov 4, 2005 | 12:33 PM
Jeff92se's Avatar
I'm needing a caw
You can change the parts w/o draining the fluid. But be ready to throw all the clothes you were wearing away.
Old Nov 4, 2005 | 12:45 PM
mtrai760's Avatar
As well as washing your hair, face, and body with dish soap about 10 times, and being stuck with that smell in your nose for a week.
Old Nov 4, 2005 | 12:49 PM
njmodi's Avatar
Do I get a tax break?
Aromatherapy. And don't stand near the fireplace...
Old Nov 4, 2005 | 02:52 PM
Dan's Avatar
Dan
I'm not lazy. I know how much the full capacity is, I was wondring how much I would need if it only gets partially drained.
Old Nov 4, 2005 | 02:57 PM
Jeff92se's Avatar
I'm needing a caw
If it's been in there for more than about 10,000 miles, just change it. If you are asking these questions, you really should be searching,reviewing the stickies (there are more than one excellent write ups) and have at least a cheap Haynes/Chiltons service manual.
Here I'll even do the work for you. Keep this EXCELLENT website in your favorites and refer to it frequently. It doesn't cover everything but what it DOES cover is done very well.
http://www.motorvate.ca/mvp.php
Old Nov 4, 2005 | 03:00 PM
mtrai760's Avatar
How can anyone here guess that? Partially drained by how much? 1qt? 2qt? That is a freakin retarded question!
Old Nov 4, 2005 | 03:23 PM
Dan's Avatar
Dan
Perhaps some more background info would clear things up:
-Tranny fluid was changed in march. (About 3K miles ago).
-I will be ordering OEM 5th gen clutch parts and having a local mechanic install
-I want to know what else I will need to order before having it done
lowpost99
Oct 26, 2025 06:53 PM
sctludwig
Sep 1, 2022 01:32 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
