I keep getting the O2 code even after I've replaced it twice!
Old Nov 5, 2005 | 04:14 PM
HarrisH's Avatar
I have a vq35 '97, I initially had the Bosch o2 sensor from NAPA, that was in a Budget Y pipe, the front right one is in question, after a couple of weeks I got the damn 0503 code, I was like fine whatever let me get a new OEM one, so I got a new one from Nissan, and I replaced that when the cattman headers were installed, NOW the damn 0503 code is back! What the hell???
Old Nov 5, 2005 | 04:21 PM
njmaxseltd's Avatar
0503 oxygen sensor or circuit fault, right bank.
Check the circuit (wiring) for any faults or resistance issues. Make sure the connections are clean and secure. Spray some WD-40 onto the plugs or put a dab of conductive grease on each pin.
Old Nov 5, 2005 | 04:39 PM
white97gxe's Avatar
Sorry this has nothing to do with your question, but i noticed you lived in jersey. Where did you get your 3.5 installed? Ive been looking for a place that was close to ny to do it.
Old Nov 5, 2005 | 04:53 PM
2 MaXiMuS 4's Avatar
Maxima.Org's Official Lurker
IIRC, Tilley did it for him
Old Nov 5, 2005 | 05:02 PM
Nismo3112's Avatar
Custom User Title
Gotta be the connections...
njmodi's Avatar
Do I get a tax break?
0503 - front right back o2 sensor.
Which o2 sensor have you been replacing? The one that is bad is the front o2 sensor in the y-pipe closest to the firewall, not the one closest to the radiator.
Old Nov 5, 2005 | 05:17 PM
Groundz's Avatar
The last o2 sensor I got for my 99 from the dealer was also a bosch. That was the reason I went to the dealer, to get away from the bosch. But I got one anyway. No problems with it tho, It's been in for about 1500 miles and never a cel yet. (knock on wood)
Old Nov 5, 2005 | 10:08 PM
HarrisH's Avatar
Yeah I have replaced the front right o2 sensor, this would be the one closest to the firewall. I will try spraying WD-40 into the connectors.
Old Nov 8, 2005 | 07:35 AM
521921's Avatar
Having same problem.
Old Nov 8, 2005 | 10:16 AM
qbvu911's Avatar
Did you check the fuse?
Old Nov 20, 2005 | 02:51 PM
bwitte's Avatar
Harris, if you have not gotten this straightened out yet, you may have an issue where your headers/y-pipe removed a precat, and you are getting a CEL because your 2ndary 02 sensors are kicking an error w/o the precats. If this is the case, you could relocate your 2ndary o2's behind your main cat, or use an o2 sensor simulator.
Old Nov 20, 2005 | 08:02 PM
96nismomaxi's Avatar
.org window licker
figure out what it sends to the ecu and replace it with a resistor
Old Nov 23, 2005 | 09:18 AM
Endlesswave's Avatar
check the exact code. it looks like your third one has gone
lux97Max
19
Aug 27, 2015 07:48 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
