Lowering my car
Old Nov 6, 2005 | 10:03 AM
Dejenn21's Avatar
Lowering my car
if i lower my car about 1.3 inches, will the ride be very bumpy because the new springs will be more stiff? i have heard that from a friend but i was not sure what lowering my car 1.3 inches will do.
i need some opinions and advise from people who have lowered their car.
thanks
Old Nov 6, 2005 | 10:17 AM
culejoe's Avatar
Ya i was wanted to know the same thing i was thinking about 1 to 1.5 inch somewhere.....
Old Nov 6, 2005 | 10:26 AM
i30dvr's Avatar
i will be a little stiffer but it will be very bouncy if you don't get a stiffer shock. Using a stock strut and lower aftermarket spring will cause it to bounce alot!
Old Nov 6, 2005 | 02:16 PM
86maxima96's Avatar
I Broke OT
it will be a stiffer, rougher ride obviously. you can probably get away with riding on stock struts for a short while. some last a year or more, others blow in only a month or so. just save up and do it right the first time. the only thing that will improve from dropping on stock struts will be the look of the car, definitely not the handling.
Old Nov 6, 2005 | 02:30 PM
hitman4's Avatar
I would not say that its only the look. As a matter of fact i maxed out at 60 on the same turn with stock springs. Lowered my car....um cant realy say how low but...the lowest I could go, and I went through the same turn at about 75. Maybe its just in my mind or i was just too afraid to go faster on stock springs, but i shure feel less wobble when jerking the wheel.
Old Nov 6, 2005 | 02:55 PM
i30dvr's Avatar
i mean *it not I
Caracicatriz's Avatar
What was that?
I'm assuming you guys are talking about the H&R springs? If So then the ride won't be too bad as long as you get some good adjustable shocks(illuminas). The springs will also make your car handle better. It will still reach its limits at low speeds if you have the stock tires on. I'de say that is the most important part of the suspension: the tires. My illuminas actually feel softer than stock.
Old Nov 6, 2005 | 03:01 PM
99SEL4ME's Avatar
i mean *it not I
Yeah, we don't need to know if you're stiff or not. Too much info.
Old Nov 6, 2005 | 08:04 PM
gto400no1's Avatar
no matter what if you lower the car on springs the ride will be rougher. i notice no bounce on my setup but i also got the illuminas with it. if you want a smoother ride you will want to go coil over.
Old Nov 8, 2005 | 01:49 PM
Dejenn21's Avatar
how much would decent coilovers and springs cost me?
Old Nov 8, 2005 | 01:57 PM
kormax97
coilovers and springs?
millions of dollars
Lakersallday24
Jun 16, 2019 01:35 AM
twotonezed
Aug 16, 2015 08:10 PM
soon2ownmax
Aug 13, 2015 02:19 PM
classymax420
Aug 6, 2015 06:35 PM
laparka66
Aug 6, 2015 09:36 AM
