Stiffest lowering springs
Old Aug 11, 2015 | 04:42 PM
twotonezed's Avatar
Had the maxima out today just driving to the grocery store. Noticed when I took a turn that the suspension is quite soft. Comfort...pish posh. What is rated the stiffest lowering springs? Who has them and what are your opinions?
Old Aug 12, 2015 | 05:38 AM
MaximaDrvr's Avatar
All of the lowering springs are progressive rate.
It you want actual stiff springs you will need coil overs.
Old Aug 12, 2015 | 07:27 AM
cheftoo's Avatar
I purchased these will install on Monday and report back.
http://www.proimporttuners.com/parts...coilovers.html
Old Aug 12, 2015 | 08:16 AM
Team STILLEN's Avatar
Former Sponsor
Lowering springs will improve handling, but if you want the most performance, go coil-over. It just depends how much you want out of the car and your budget. You can PM me if you have questions.
https://www.stillen.com/suspension/l..._campaign=jill
Old Aug 12, 2015 | 11:34 AM
twotonezed's Avatar
I understand that springs are progressive. The thing is they must progress to some point. I would do coilovers which would just mean that I would have to save for a longer period of time but our roads up north here are awful. We get potholes, frost mounds, uneven roads. With lowered cars you actually have to teach yourself which roads you can and cannot go down to get to a certain location.
Old Aug 12, 2015 | 11:39 AM
twotonezed's Avatar
Has anyone looked into or installed RS-R springs. I am hesitant to purchase them because of the inconsistency I have found.
One place said that the lowering would be 1.2-1.4 front and .6-.8 rear with spring rates of 5.54kg/mm front and 3.67kg/mm rear.
Another place says lowering is 1.2-1.4 front and rear and spring rates are 2.75kg/mm front and 4.79kg/mm rear.
Those two are quite different for being the same spring.
Old Aug 12, 2015 | 12:21 PM
MaximaDrvr's Avatar
They are progressive springs, so you can't give a single rate.
The BC coils on their longest setting will only lower the car minimally, while still keeping the benefits.
Old Aug 12, 2015 | 12:40 PM
dmcmahan12's Avatar
Sorry but if the roads are that bad then go with the Eibach's or RS-R lowering springs so you can have a bit of drive ability. Just my opinion. I have had lowered and they are fun for a while but to me you get tired of the ride being too stiff.
Old Aug 12, 2015 | 08:04 PM
fame126's Avatar
Originally Posted by twotonezed
Has anyone looked into or installed RS-R springs. I am hesitant to purchase them because of the inconsistency I have found. One place said that the lowering would be 1.2-1.4 front and .6-.8 rear with spring rates of 5.54kg/mm front and 3.67kg/mm rear. Another place says lowering is 1.2-1.4 front and rear and spring rates are 2.75kg/mm front and 4.79kg/mm rear. Those two are quite different for being the same spring.
i have had the rsr springs for about 6 months now. I love them! Handle well no noise not too low. Very happy with them. I will post pics tomorrow after car is washed and during the day
Old Aug 12, 2015 | 08:16 PM
1996blackmax's Avatar
I thought someone on here had them.
Old Aug 12, 2015 | 09:01 PM
twotonezed's Avatar
fame- What are the specs of the wheels and tires you are running with the RS-R springs? Please post when you post those pics. Thanks.
Old Aug 13, 2015 | 04:06 AM
Tommy6905's Avatar
I have to agree, handling is great but trying to avoid every pothole is near impossible, and it always seems when you think you missed one, you hit another.
Old Aug 13, 2015 | 11:27 AM
Former Sponsor
RSRs drop about 1.2 - 1.4 inches, front and rear, according to the specs I have.
Always best to give RSR a call and ask them based on part number. (N910D Is the one we have.)
I honestly don't know how that amount of drop would fair in your conditions.
If you don't want to go lower you could try sway bars, but that won't really help a lot with "softness," over bumps and such... mostly the turny bits.
Old Aug 13, 2015 | 07:24 PM
fame126's Avatar
On rsr springs
Old Aug 13, 2015 | 07:27 PM
fame126's Avatar
245 45 18's all around
Old Aug 13, 2015 | 09:46 PM
Ross2893's Avatar
Originally Posted by fame126
On rsr springs
Uhh the angle you took those pictures shows everything but new height of the car. So hard to see the drop of the car when you take slanted angles instead of just side angles..
Car looks good though
Old Aug 13, 2015 | 10:27 PM
fame126's Avatar
I will take a better pic tomorrow so you can get a better idea.
Old Aug 16, 2015 | 08:10 PM
fame126's Avatar
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
