Transmission leak at axle
Old Nov 7, 2005 | 01:54 PM
venompwr2's Avatar
I could use some help on taking care of a transmission leak that seems to have popped up. Its on the 5spd on my 95 max, where the left axle (drivers side) goes into the tranmission. Two or three inches of the axle is wet with fluid and the surrounding area is too. After about 2-3 days of sitting in one place, the ground is wet too, about the size of a half dollar. Its not a terrible leak, but if it can be fixed that would be a lot better. Anyone have any tips?
Jeff92se's Avatar
I'm needing a caw
Um replace the seal?
Old Nov 7, 2005 | 02:05 PM
dgeesaman's Avatar
Maintenance Monster
Grab that axle and give it a firm shake. If there is play, your problem will not be solved by replacing just the seal. (search for "differential carrier bearing")
Dave
Old Nov 7, 2005 | 04:30 PM
Torgus's Avatar
replace seal it is the ONLY possible problem if the gear oil is leaking out thats the only place. period. from a dealer in ma it will cost about 6 bucks.
Old Nov 7, 2005 | 04:36 PM
venompwr2's Avatar
Thank you I'm not driving the car now, its off the road for the winter, and I planned on changing the gear oil too. I just bought this car a week ago, and I can tell the previous owner wasnt a car enthusiast so I have to make some changes to things and get it running more smoothly. Thats the only major problem, but it can use a tuneup as well.
Old Nov 7, 2005 | 05:34 PM
dgeesaman's Avatar
Maintenance Monster
A new seal is the only possible problem and solution? I think that's a little short-sighted.
Excess play due to worn carrier bearings will allow the axle to move beyond the range of motion of the seal and leak even if the seal is perfectly good. Worn carrier bearings are an all-too-common problem on the 5 speeds. If this possibility could in no way apply, I'd like you to explain how.
Dave
Old Nov 7, 2005 | 05:49 PM
Mishmosh's Avatar
dGEESAMAN is totally correct. I think it's more likely to be the differential carrier bearings than the seal given how pervasive the problem is. Like he says, check for play in the axle end and you will have your answer.
Old Nov 8, 2005 | 05:06 AM
Wheelie King's Avatar
Play in the differential carier bearing? Is that one of the joints in the axle? If so then will that make a noise while driving? I'm getting a hum and some clunking when I turn right (except when I tap brakes or gas). I checked the axle yesterday and I can hol the end closest to transmission and twist the outer end (other side of joint) slightly. There is more play than there should be. Is this what you mean by play in differential carier bearing? I'm replacing the axle yto solve the problem.
Old Nov 8, 2005 | 05:16 AM
dgeesaman's Avatar
Maintenance Monster
See: http://forums.maxima.org/search.php?searchid=332486
The carrier bearings are just inside the differential housing, and each one holds the inside of the axle. So a bad carreir bearing will allow side/side movement of the axle right near the housing.
If you were twisting it, you might be noticing the gear backlash in the diff, which is normal.
Dave
Old Nov 8, 2005 | 05:47 AM
Bobo's Avatar
I have the identical car and I, too, have a leaky left tranny seal. My car is a Canadian model with LSD and I am confident that all that needs to be replaced is the tranny seal. The vehicle has less than 61,500 mostly highway miles on it and is making no strange noises and shifts perfectly. There is no play in anything.
Old Nov 8, 2005 | 09:06 AM
MaximaSE96's Avatar
Maxima Owner
its the seal justin....autoplace stocks them
Old Nov 8, 2005 | 05:24 PM
venompwr2's Avatar
I have some time tomorrow, I'll check if there is play and stop there and pick up a seal too. Thanks Chris.
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
pjgreek
Sep 9, 2015 09:30 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
