Is it my o2 sensor? Please help me...
Old Nov 11, 2005 | 12:55 AM
lexx426's Avatar
Okay, so here is the story. I installed a WS y pipe today. Took a little time but that is okay. When the y pipe came off, the o2 sensors were still attatched and the rear o2 sensor was jerked pretty hard. I didnt think too much of it so i just took them off and went on with the install.
After it was all installed i drove the car for a while and it was feeling really wierd. Throtle responce was all messed up. It even back fired twice (or it sounded like backfire) Now at the end of the night my check engine light is on... I'm going to go check it tomorrow but does anyone know of a reason, or a posible common theme of a y pipe side effect.
Thanks guys,
Art
Old Nov 11, 2005 | 02:10 AM
MaximaSpd85's Avatar
Very well could be, the day i had my y-pipe installed my o2 sensor got screwed up by the installer. I guess they're fragile?
Old Nov 11, 2005 | 03:11 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Just pull that code and you will know for sure. Porbably that o2 sensor is bad. Its not too hard to replace. Just follow the wire up to the top of the engine bay and you will find the end of the harness. Just unplug it, plug in teh new one and drop it back down.
Old Nov 11, 2005 | 03:50 AM
blkmax9600's Avatar
When U Put On A New Y Pipe U Should All Ways Replace Old O2 Sensors Preventive Main Is A Must People I Have A Ws Y Pipe And 2 1/2 Inch Cat Back On The Way. I Have Not Got New O2's Yet Because I Have A Lean /rich Air/fuel Gauge Going In I'm Trying To Get A Good Wide Ban 02 Any Ideas?
Old Nov 11, 2005 | 04:30 AM
njmaxseltd's Avatar
Completely faulse.
Do You Really Think Any Body Will Take You Seriously If You Type Like This?
It's called grammer, check it out.
Old Nov 11, 2005 | 06:20 AM
blackmaxx96's Avatar
There's never a day when something's not on sale
why do you want a "lean/rich air/fuel gauge"
Do you have some kind of modification that is going to change the A/F ratio controlled by the STOCK ecu???????
There really is no point spending so much money on a wideband, and an expensive wideband o2 gauge, if you don't have FI, spray, or if you have an safc or other fuel computer hooked up to change the a/f ratio.
Old Nov 11, 2005 | 10:18 AM
lexx426's Avatar
Ok, I will run the code today. How much do o2 sensors usually go for? And is what i explained usually what happens when o2 sensors are bad? idle droping too low and sputtering a little, and not as responsive at lower rpms.
Old Nov 11, 2005 | 12:38 PM
lexx426's Avatar
Okay, now i am confused. I ran my codes and it came up (P0325, Knock sensor one circuit malfunction, bank 1 or 1 sensor)... What is that? Has anyone ever fixed that? Where should i get the parts, and how much?
Old Nov 20, 2005 | 02:34 PM
bwitte's Avatar
When you put a performance y-pipe on, I would think that you want to bypass you're secondary 02 sensors with an 02 sensor simulator, or else you will get a CEL. I'm in the process of doing that, as I just installed a cattman y-pipe.
Old Nov 20, 2005 | 02:46 PM
scrhale's Avatar
O2 Sensor Simulator??? The Downstream O2 Sensor does not affect A/R Ratio. First of all, your downstream O2 Sensor is in your Cat or B-Pipe and should not be touched during the install. Second, I have never heard of anyone using O2 Sensor simulators after a y-pipe install.
Old Nov 20, 2005 | 02:49 PM
Vlasic's Avatar
Ya, what the hell are you talking about? Why would you need a simulator and why would you get a CEL after a ypipe install?
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
