Hub Retaining Nut Torque
Old Nov 14, 2005 | 04:20 AM
Wheelie King's Avatar
How much torque do I need to tighten my hub retaining nut? Anybody know?
What happens if I used significantly less torque? Will that damage the axle? I just replaced my axle and it seems to be making humming and crunching noises.
Old Nov 14, 2005 | 04:54 AM
njmaxseltd's Avatar
Haynes says 174 - 231 ft/lbs.
Old Nov 14, 2005 | 03:54 PM
ThurzNite's Avatar
it'll loosen up till it hits the cotter pin if it's not tightened all the way. Use a breaker bar and put your weight on it. If you're significantly underweight, throw on a pipe and extend the breaker bar for more leverage.
Jae
Old Nov 14, 2005 | 06:05 PM
Thanks, that helped me quite a bit. I've been hearing a crunching sound from my axle. I tightened the nut and it went away. The nut only turned a little but it did the trick.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
