Help ASAP I bought a frankencar midpipe and dont know how to install
Old Nov 15, 2005 | 03:45 PM
Mxrider52's Avatar
I support for what?
I bought a frankencar midpipe off a member here on the org and I received the following
midpipe, 2 couplers t-bolt clamps, hose, and MAF adapter
I have an existing popcharger on my max but I cannot make it fit. Here a picture of my popcharger on my car now. Click to enlarge.
Old Nov 15, 2005 | 03:52 PM
kormax97
dunno how anyone can help you if you don't know how to change a midpipe from an intake. just unbolt everything and put the d@mn thing in...
Old Nov 15, 2005 | 03:54 PM
Mxrider52's Avatar
I support for what?
It won't fit it is to long
Old Nov 15, 2005 | 03:56 PM
NmexMAX's Avatar
dot dot dot ...
Couplers go over TB and rear end of MAF ... with the M/P in the middle.
Old Nov 15, 2005 | 03:57 PM
Mxrider52's Avatar
I support for what?
I have everything off I put the couplers on the midpipe then add it to the throttle body then go to add the filter with the MAF and it to long and it won't bolt to my bracket under the filter
Mxrider52's Avatar
I support for what?
Is my filter to big or what
Old Nov 15, 2005 | 04:00 PM
kormax97
are you sure the cuplers are alllll the way in on both ends? it might save you inch or two if you do it correctly. why don't you put the franken midpipe next to your stock midpipe in that picture and show us.
ps. your filter is WIDE but it doesn't look long enough to cause the problem
Old Nov 15, 2005 | 04:01 PM
Mmmaxx's Avatar
shouldn't be to big at all, if you can post a picture of what it looks like right now.
NmexMAX's Avatar
dot dot dot ...
Just install the stock lower airbox piece and let the fitler rest on it like that.
Old Nov 15, 2005 | 04:02 PM
kormax97
OT: Where do you work?
Old Nov 15, 2005 | 04:05 PM
Mxrider52's Avatar
I support for what?
OK I am taking a picture of how the whole setup with the midpipe is right now and showing how it wont fit
Old Nov 15, 2005 | 04:07 PM
NmexMAX's Avatar
dot dot dot ...
24 M NW of the capital city.
Old Nov 15, 2005 | 04:11 PM
Mxrider52's Avatar
I support for what?
Here are the pictures. Click to enlarge. I have also found no use for the MAF adapter.
Old Nov 15, 2005 | 04:13 PM
NmexMAX's Avatar
dot dot dot ...
Do what I said in post # 9 .... I had mine like that for years until I saw a dyno with the hybrid set-up
Old Nov 15, 2005 | 04:19 PM
Mxrider52's Avatar
I support for what?
Then what?
Old Nov 15, 2005 | 04:20 PM
Mxrider52's Avatar
I support for what?
And none of my hoses are long enough either except for that small one
NmexMAX's Avatar
dot dot dot ...
Call it good since you wont need the brakcet holding it It will rest on the lower 1/2 of the airbox
Old Nov 15, 2005 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
You must've got jipped b/c my FC came with an extra hose to use for the IACV... ....
Old Nov 15, 2005 | 04:43 PM
kormax97
You definitely need new hoses... I needed them at least. In the picture, rest looks fine to me.
Old Nov 15, 2005 | 04:53 PM
Mxrider52's Avatar
I support for what?
How do I support the filter from dropping? There is no other brackets beside the one in the picture
Old Nov 15, 2005 | 04:58 PM
joosdawg's Avatar
get at least one new hose for the IACV, the crankcase vent one should be able to stretch.
Old Nov 15, 2005 | 05:11 PM
Mxrider52's Avatar
I support for what?
I got one hose but it doesn't look long enough but oh well I give up until tomorrow or this weekend
Old Nov 15, 2005 | 06:01 PM
kormax97
Go get some hoses.. I don't know the diameter or whatever you need but shouldn't be that hard to find. Also, mine came with this bracket thing to hold it in place but right now it's not even on there and it's fine even without that little bracket thing. You can probably find one to hold it in place at like Home Depot. Use your imagination.
Old Nov 15, 2005 | 06:10 PM
NmexMAX's Avatar
dot dot dot ...
Didn't I just answer this question?
Old Nov 15, 2005 | 06:14 PM
bhmax16's Avatar
The couplers are stiff enough that no extra support is really necessary. I drove with my frankencar for a long time with no brackets supporting it. After a while I bolted a small spring I found from the MAF to a bracket with a hole in it near the strut tower. The spring sort of acts like a shock absorber. Works for me
Old Nov 15, 2005 | 06:15 PM
RA030726's Avatar
I'm nutty for Nissans
damn this is getting crazy, its not rocket science.
Old Nov 15, 2005 | 07:42 PM
Iron Scimitar's Avatar
Tha Snatcher
He bought the intake from me. I sent him everything i had gotten w/ the intake except one more hose clamp which probably gotten lost. I told him that i'll get him an additional hose clamp. But as far as the hoses go, i sent him what i received from FrankenCar.
I also noticed that he isn't using the MAF adapters like i was using w/ my APEX-i cone which could decrease the length of the intake, but using the lower half of the stock airbox would help support the cone from moving as NmexMAX suggested.
He didn't get jipped, i sold the intake to him for only $50 bucks which would've costed him $80 dollars from FrankenCar w/o a filter.
Old Nov 15, 2005 | 08:09 PM
NmexMAX's Avatar
dot dot dot ...
You write that as if you don't think i know these things ..
I paid 60 for my midpipe straight from frankencar, but you guys have to get all fancy and get the shiny version.
FC is weird, as I did not get the coolT bolts, but mine did come with an extra hose for the IACV hook-up ..
Old Nov 15, 2005 | 08:11 PM
gtr_rider's Avatar
192.168.1.1
Try this: http://www.vqpower.com/v2/modules.ph...article&sid=54
Old Nov 15, 2005 | 08:53 PM
99grnmaxgxe's Avatar
Or you can go the Frankencar's website and they should provide instructions on how to install the intake.
Old Nov 16, 2005 | 03:58 AM
Tha Snatcher
Srry about that buddy, I sometimes feel that i have to explain myself to ppl around here.
Old Nov 16, 2005 | 06:46 AM
jrbeilke's Avatar
Yea check out Frankencars site for instructions, and for hoses you're either going to have to pick up some new ones somewhere local or see if Frankencar will send you some b/c it looks like you're missing some.
I've got a midpipe also and I only got one coupler so I had to reuse one of the stock couplers. I was also able to use some random brackets to support my filter from the strut tower to the battery tie down in this pic>>>
Old Nov 16, 2005 | 09:50 AM
^^^^Wow looks unique and interesting, I've never seen a FC midpipe with the stock coupler used.
Old Nov 16, 2005 | 09:52 AM
NmexMAX's Avatar
dot dot dot ...
Actually, now you have.
JRod28
Dec 29, 2023 09:56 PM
maxfever1987
Nov 19, 2016 08:01 PM
Samedi
Aug 13, 2015 04:05 PM
