*HELP* 96 i30 auto, tach goes down when accelerating???
hey guys, on our 96 i30 when accelerating the tach goes down from the idle 700-800 not up... but the engine is reving up.... you can hear it, these are the three codes i pulled
p0150(o2 sensor)
p0325(knock sensor)
p0130(??? in the stickie there are 2 diagnoses, o2 sensor or closed loop control??)
what could the problem be? kinda scared my sister, boggled my mind...
HELP!
p0150(o2 sensor)
p0325(knock sensor)
HELP!
p0150(o2 sensor)
p0325(knock sensor)
HELP!
p0150(o2 sensor)
p0325(knock sensor)
HELP!
ionno if it happens all the time, my sister told me about it, and i reved it in park and it went down.. kinda scared to push it any farther... ive never heard of this ever happening... im more than confused right now...
Originally Posted by jetblack5spd
same thing used to happen to my 96 maximas temp gauge. when accelerating it would bounce down and up again. after i installed my intake it went away and never happened again. i dunno im just saying
An intake won't solve your problem if that's what you're trying to say...
Anyway, replace your appropriate sensors because you will want to regardless, and look into the "closed loop control" diagnosis.
In the meantime, BUMP for a guy who needs some help.
anyone think that its a bad idea to drive? i mean the engine is still reving correctly and al...
well i personally havnt driven it yet, but i believe that it still is shifting correctly, the check engine light has been on for a while, maybe ill reset it and see what pops up next
when it shifts the rpms go back up to abour 1k rpm, and than go down again.. drives fine... any safety issues i should be worried about? or does it seem like its just a guage problem?
Does this happen when it downshifts? At any other time the needle seems to be working but it's really about 1k lower than where it should be? If that is the case, then we have the same problem (95 max auto). In my case it's the tachometer that's bad and I have to change the cluster. I've had it like that for almost a year now and no problems (no codes either). It does work sometimes though, but only when it feels like it.
p0150(o2 sensor)
p0325(knock sensor)
HELP!
p0150(o2 sensor)
p0325(knock sensor)
HELP!
Ahh shoot, didn't notice the dates when I was searching. Well I have the problem described in my post above. In the five years since this post has anyone else had this problem?
Car rides great otherwise. It is an automatic so its not really important that I have the tach working but I like to see my RPM.
Hey guys,
I have kind of the same problem with the rpms.
they rev fine when im driving but then when i come to a stop it goes down to 0 and stays there. after I start to drive again, it still stays in 0 and after like 10 second it goes back to normal. by the way it just started doing it today when i was going home from work. Any advice?
Finkle
09-27-2015 09:53 PM
kirkhilles
08-08-2015 10:53 AM
